Old 09-09-2010, 11:29 AM
jac1502 jac1502 is offline
jac1502 is on a distinguished road
Default New guy to the 5.7 and need some advice
First off hello to the forum members that are reading this!
Although I dont have a ram; I do however have a ram 5.7 hemi and trans that I am installing in a 1997 wrangler (see pics below)
My first question is basic. With a complete engine and trans where should I mount the chains from the engine load leveler?
Seems the manifold might not be the best choice and at this time i dont know if I will be using stock manifolds due to clearance.
Thanks in advance, I am sure once I get the mounts in i will begin the performance upgrades prior to final instalation.
JC
Old 09-09-2010, 12:20 PM
Rep:1824
The Hemi uses a special lift bracket that only the dealer will have. Just find something solid to bolt the leveler to.
Old 09-09-2010, 06:31 PM
chefred112's Avatar
chefred112 chefred112 is online now
Vehicle: 2005 Dodge Ram
Rep:650
ooo...what year motor and vehicle did it come out of..are you using the pcm as well?
-fast freddie-
one quick 05 hemi qc...with over 250k miles on odo... on the 5.7...stoker 6.4 now, new times coming
performance mods: yes 1/8 - 7.85 @ 93.20, 1/4 - 12.10 @ 113.96
Old 09-09-2010, 06:33 PM
chefred112's Avatar
Rep:650
just noticed...came out of a charger or 300...please update us as you move forward with this install..
-fast freddie-
Old 09-09-2010, 06:41 PM
RootBeer RootBeer is offline
Vehicle: 2011 Chevy 3500HD
Rep:1287
Welcome to the Z. Now that you started the project here, you ARE obligated to keep us posted with progress reports and pics of course.
Brian:
Old 09-09-2010, 06:51 PM
Rep:2608
take off the plastic engine cover first, & then you will see where you can attach the chains for lifting, i personally remove anything in the way of attaching a plate directly to the intake manifold, stick clean rags in any holes that a bolt can drop into, then bolt this tool that can be found at any auto parts store & your engine leveler hooks into it & of course your engine hoist to that
http://www.autozone.com/autozone/acc...er=266025_0_0_
Old 09-09-2010, 09:37 PM
I will keep everyone updated.
I am planning on using the wiring harness and PCM out of a Ram. I just picked up a 4x4 transmission today.
I do not plan on taking off the intake so where am I to mount the plate?
Can I remove the four outer most intake or valve cover bolts and replace longer bolts not threaded down all the way? See image below
I am weary of breaking the intake or stripping anything and straps are a pain in the ass and not very safe
Old 09-10-2010, 12:31 AM
chefred112's Avatar
Rep:650
i wouldnt lift it by the valve cover bolt..too thin...
-fast freddie-
Old 09-10-2010, 01:11 AM
Rep:1287
based on that picture, the only option I can see is making a cradle out of straps.
Brian:
Old 09-10-2010, 04:21 AM
ram71351's Avatar
ram71351 ram71351 is offline
Trim Level: SLT Big Horn
Rep:45
ram71351 is on a distinguished road
Welcome... I've seen a company in Nevada put Hemi's in two jeeps. Can't remember the name though. They had a program on TV (A&E I think) that showed them putting them through the paces (heat, snow, etc.) and they performed very well. I always wanted to do it myself. By all means keep us updated.
Rams are mans best friend !!!!
