Old 09-25-2010, 05:26 PM
hillvalley hillvalley is offline
hillvalley is on a distinguished road
Default 94 5.2 oil pressure problem
I have a 94 1500 with the 5.2. the oil pressure is bouncing around on the guage. It will be fine one minute then it will drop to 0 then back up.. changed oil and filter still doing it.. Im goin to try a pressure switched and thought about dropping the pan to check the filter screen on the oil pump. any other suggestions.. thanks
Old 09-25-2010, 05:43 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I'd do the easy stuff first like the sensor/sending unit.
Brian:
Old 09-25-2010, 05:52 PM
Rep:1885
I'd get a mechanical gauge and check the pressures first. If you try a switch first and it doesn't change anything, you've thrown away money and ran the engine without oil pressure yet again.
Old 09-25-2010, 10:52 PM
How many miles do you have on it ? Definitely take a reading first with a mechanical gauage after you take out the stock sending unit . I'm not sure if their still putting in the nylon coated timing gears anymore but if they are and you have any significant mileage on it , it may be the screen in the pump clogged up with the nylon . Seen it many times on older engines .
