Old 09-26-2010, 12:06 PM
colingibb colingibb is offline
Vehicle: 2008 Dodge Ram
Rep:19
colingibb is on a distinguished road
Exclamation Please Help with Alternator Whine after new H/U Install!!!
Okay, so I've installed my new H/U (Clarion NX500) in my 2008 Dodge Ram, and I've got faint alternator whine when revving the engine.
Here's what my configuration was before the install (there was no alternator whine):
- Factory Head Unit
- Audiobahn A4004T Ampifier under the driver's seat
- New heavy duty speaker wiring run directly from the AMP to all 4 door speakers.
- tapped into the factory speaker wires from the side of the car to get the audio to the amplifier.
Here's what the latest install included:
- Installed the Clarion NX500 (replaced the dash bezel with the NAV bezel to maintain a clean, facory look.
- Used a bypass that I got off ebay to bypass the brake connection ( to allow full functionality when the parking brake is off).
- used the PAC harness from Crutchfield.
- connected RCA cables (SCOSHE cables from Wal-Mart directly from the H/U outputs to the Amplifier inputs.
- Used the factory harness ground to connect the NX500 ground to (I know this is less than ideal, and if needed I can remove this wire, and connect to a better ground, but I want to work through some troubleshooting and know this is neccessary before doing this.
Here's what I've done so far to troubleshoot the whine:
- Removal of the RCA cables from the amplifier does not stop the alternator whine.
- Removal of the RCA cables, and replacing them with shorting plugs as suggested here (http://decibelcar.com/index.php/menu...65-enginenoise) does elliminate the alternator whine.
- Installation of two ground loop isloators behind the H/U between the Head Unit and the Amplifier actually makes the whine worse (that shocked me).
- Checked the ground on the amplifier -- it's currently connected to one of the bolds holding the seat down to the body.
I'm not sure where to go now -- since testing with the shorting plugs elliminated the alternator whine, I have to assume that it's coming from either the H/U or the RCA cables.
Would it make sense to plug the shorting plugs into the RCA cables behind the H/U to determine if it's coming from the RCA cables or the Head Unit?
Also, why would the noise persist when there is nothing plugged into the amp, but stop with the shorting cables? Does this tell me anything? Or is the noise just being picked up somehow by the RCA inputs of the Amplifier?
This is driving me crazy, hopefully with the steps outlined above somebody can shed some light into the next best step...
Btw, I absolutely love the Clarion NX500 - I put the GPS antenna in the center speaker hold. I used a faceplate (cut it up to fit in the speaker) attached to the speaker mounting holes (the holes in the faceplace or 3.5" wide -- the same as the speaker bracket - very cool) and then put the gps antenna on the faceplate and taped it down. I have excellent reception with the gps antenna in that location.
Thanks so much!!
Colin Gibb
Old 09-27-2010, 10:50 AM
dodgeman70592's Avatar
Trim Level: Custom
Rep:1648
- Factory Head Unit
Thanks so much!!
Colin Gibb
I would suggest using a ground lug type connection for you amp instead of the seat bolt. I would also make sure your RCA's are not run along the same area as the power cable for the amp. The shielding on the RCA's you have may be light, so checking into a liitle highre quality RCA may be in order too.
Old 09-27-2010, 11:11 AM
Rep:1885
I'd be tempted to try another aftermarket HU as well, if you can get your hands on one.
Old 10-03-2010, 04:57 AM
97ram1500 97ram1500 is offline
Vehicle: 2014 Dodge Ram
97ram1500 is on a distinguished road
im not an expert but check to see if the floor where the bolt goes into for ground for the amp has paint on it, if theres paint it'll create a shitty ground in most cases. Maybe try picking a different ground point
Old 10-03-2010, 07:53 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
sand all paint off a smooth place, drill new hole, attach w/ a nice screw that goes in tight (thats what she said). If that doesn't work, new RCAs.... if you got a bulk wiring kit, I'd bet that is the issue.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 10-19-2010, 11:27 PM
cwking25 cwking25 is offline
cwking25 is on a distinguished road
You also might want to just run a bigger ground from the HU to the same ground as your amp ( which btw i would find a better ground, somewhere on the frame if you can ). The owner of a Car Audio shop where i live has been telling me that for years about grounding the HU in the same place as your amp, so i finally started doing that and no more whine. Now i always run that ground just to make sure, plus ive heard when you start putting more grounds in the truck , your increasing the chance of a ground loop. just my 2 cents, hope it helps
alternator whine noise
