Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 09-26-2010, 02:50 PM
69speeder69's Avatar
69speeder69 69speeder69 is offline
Vehicle: 2001 Dodge Ram
Trim Level: Laramie SLT
Rep:18
69speeder69 is on a distinguished road
Default Whats goin on
My heater hasnt been working and my gauge has been saying about 160 degrees. So i changed my thermostat and now when i turn the heater it will be fairly warm but then go back to just blowing cool air. Not cold air but definetly not warm. I need to get this figured out and solved before winter comes! Any help would be apprectiated.
Old 09-26-2010, 03:03 PM
Rep:4162
T-stat would have been my first choice, also, but definitely not right you're running that cool. I'm sure our experts here will have some advice for you on this, but good luck.
Old 09-26-2010, 03:43 PM
Rep:18
also after i changed the t stat the guage still stays around the 160 degree area. and i put a 195 t stat in.
Old 09-26-2010, 04:28 PM
Are the heater hoses staying hot to the touch ?
Old 09-26-2010, 04:54 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Sounds like a combination of things. First off, I would not be too quick to depend on the temp gauge for accuracy. I have always considered those more of a 'cold-normal-hot' gauge.
If your having a heater temperature issue, it is not usually a thermostat problem, but more likely either an air lock in the heater core, or a plugged heater core. If you check the heater hoses (after the trucks been running awhile) for warmth, this a good indication of what's going on. Under normal operation, both hoses should be 'uncomfortably' hot right where they enter/exit the heater core (at firewall). If one is quite warm and other slightly warm, then chances are its an air lock. If both are slightly warm....or cold, then likely the heater core is due for replacement.
You 'Might' be able to get away with a good cooling system flush, and I would recommend this anyway, but if the heater core is so bad that it is plugged, you might as well replace it now, because if the flush opens it up, it's likely going to start leaking in a short while anyway.
Good luck with getting your heater working for winter. No fun driving around in a cold vehicle.
brad
Interested in one of my mods?
Old 09-26-2010, 09:32 PM
Mtx's Avatar
Mtx Mtx is offline
Vehicle: 97 Dodge 2500
Trim Level: 2500 4x4
Color: hunter green
Rep:16
Mtx is on a distinguished road
i was wondering why nobody had said anything about the heater core yet^^^
Old 09-27-2010, 04:44 PM
Rep:18
K i will check my heater hoses. also i heard that i could have something to do with the head gasket leaking the way it will get warm and then go back to being cool. Does anybody else know about this or a way (besides pulling the heads off) to check the gaskets.
Old 10-13-2010, 09:00 PM
Rep:18
So i still havent found a solution to my problem. I have noticed that i have a slight leak in my radiator. Could this be what is causing my problem
Old 10-13-2010, 11:02 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
The leak in the radiator causing the problem is doubtful. Did you have the system flushed? How are the heater hoses to the touch with the heat on full hot and the engine warmed up?
As for the head gasket idea, check your oil, is is milky? Do you have oil in your radiator? Those are the two prime indications of bad head gaskets.
Brian:
Old 10-14-2010, 12:28 AM
brad12kx's Avatar
Rep:2581
And to add to Rootbeers comments on the head gasket idea, if the head gasket was leaking between he cylinder and cooling system, you would run out of coolant quickly....it will blow it out. In all cases, it is doubtful that it is the cause of your heating problem outside of possibly leading to an air lock in the heater core. So unless you have any of the symptoms Rootbeer mentioned, I would focus on either an air lock, or plugged heater core, or a heater core that is so dirty, it might as well be plugged.
brad
