Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 09-26-2010, 09:20 PM
TalalaRam's Avatar
TalalaRam TalalaRam is offline
Vehicle: 1998.5 Dodge Ram QC 4x4 Dually
Trim Level: SE
Color: Brentwood
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
TalalaRam is on a distinguished road
Default Intercooler
1998.5 Dodge 3500 4x4 Diesel
Will installing a after market intercooler make much difference in the EGT temp with a stock turbo? I use my truck for towing 18,000 lb toy hauler. Thanks in advance for you thoughts on this. If the answer is yes, is there a better after market intercooler?
Old 09-27-2010, 01:36 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Giving this one a but don't know the answer.
Brian:
Old 09-27-2010, 01:42 AM
Depends on how the material specs and capacity compare. If there is more capacity, it will run cooler. Most are made of aluminum but if one is steel vs. aluminum, it will take longer to cool down.
Check with Banks Engineering. They make good stuff that works!
Old 09-27-2010, 03:54 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
EGTs are determined by air/fuel ratio more so. I don't doubt it would lower it...but, adding more fuel would lower it even more...to a point. Don't make it over rich either, because then it will have raw fuel in the exhaust and it will ignite in the turbo which will thus cause high EGTs.
Then again, I'm speaking in terms of gas motors...diesels...for all I know they could be the absolute opposite.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
