Question? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 09-26-2010, 09:22 PM
gonzo1's Avatar
gonzo1 gonzo1 is offline
Color: Mineral Gray
Rep:17
gonzo1 is on a distinguished road
Default Question?
Just put the McGauphy's 2-4 drop kit with the spindles on my 2010 dodge ram and was wondering if the rear end had any kind of adjustment to it at all because now it seems like the rear is about a 1/2 inch off to the right. Any solutions? Also wonder why my front wheels stick out further than my rear wheels . They are all the same size. Can anyone explain why this happened?
Old 09-27-2010, 01:34 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Giving this one a but don't know the answer.
Brian:
Old 09-27-2010, 07:38 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
that's common when changing vehicle height. the only way to correct it is with an adjustable track bar.
if you look at your factory track bar you'll see that it is not adjustable so when raising or lowering the axle is pulled to either the driver or passenger side depending on which way you went.
1. get an adjustable track bar.
2. hang a plumb bob from each rear fender
3. raise the rear axle off the ground.
4. adjust new track bar to center axle using plumb bobs as a reference.
5. tighten track bar jam-nuts and lower vehicle
6. enjoy.
I just did a quick Google search and here is an example. I'm sure you can find better prices if you shop around.
http://www.klmstore.com/carli-adjust...n-rod-bar.aspx
Old 09-27-2010, 09:32 PM
gonzo1's Avatar
Color: Mineral Gray
Rep:17
Thanks!!!!! Great write up!!
