Old 09-27-2010, 01:31 AM
coreyCK coreyCK is offline
Vehicle: 1999 RAM 2500 4x4 Ext cab SB
coreyCK is on a distinguished road
Default Lift?
Hey everyone im looking to put 35"x12.5s on my 1999 2500 and I wondering if they would fit with just a 2 inch leveling kit. If anyone has pictures of their 3/4 ton with 35'sthat would be great.
Old 09-27-2010, 12:22 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I've seen a 99 2500 done with a 3 inch spacer. His 315's rubbed just a tad at full lock.
I'm sorry, don't have any pics. It was an awesome truck though.
Old 09-27-2010, 12:38 PM
I'm not sure if they would fit or not. I had to go 4" up to fit 35's but I don't have any rubbing at the top of the wheelwell or at the backside of the bumper when turning. It's pretty close to the fender at the rear, too.
12.5's may rub at full steering lock inside and if the truck isn't high enough, on your fender opening too.
Old 09-27-2010, 04:32 PM
97ram1500 97ram1500 is offline
Vehicle: 2014 Dodge Ram
97ram1500 is on a distinguished road
You'll probably need spacers more then a lift kit. I dont have a 2500, only a 1500 and no lift kit and they rub at full steering lock. I dont think a lift kit would solve that, most likely spacers would.
Heres a pic of my truck to give you an idea, I have a feeling if i put spacers on i would be fine. If I went straight lift, I'd probably have use atleast a 4inch lift
Old 09-28-2010, 12:51 AM
alright thanks for the info guys
Old 10-20-2010, 09:44 PM
96DodgeRam1500's Avatar
96DodgeRam1500 96DodgeRam1500 is offline
Vehicle: 1998 Dodge 2500 4x4 Sport
96DodgeRam1500 is on a distinguished road
i got 2WD 1500 and I only did a 1/2 Daystar Budget Boost Leveling kit and I have 315/75 BFG Mud Terrains and they scrubbed the fender well and I had to cut about 6 inches out. Other than that they dont until I do a full turn then they barely scrub on the lower control arm. I got a pic.. Ill try figuring out how to get it on here that way you have an idea on how itd look.
1998 Dodge Ram 2500 Sport 4x4. 360 all stock. Leveling kit with 315s.
Old 10-20-2010, 10:07 PM
1/2 ton here with 35's and a Daystar 2" leveling kit .
Old 10-21-2010, 01:58 PM
with the day star did you get the kit or just the spacers?
also if your truck it the off road version does it have a lift from the factory, and what is it?
thanks
Old 10-21-2010, 05:54 PM
its just the spacers.. no mine aint the off road version. its just a 2WD so it was stock height.. mine is a 1500 laramie SLT..
Old 10-21-2010, 09:47 PM
ha... brain fart ... i just realized you were asking Tom them questions... but yea you should be able to squeeze them 35s on your truck with no problem.
