Old 10-22-2010, 11:31 AM
coreyCK coreyCK is offline
Vehicle: 1999 RAM 2500 4x4 Ext cab SB
coreyCK is on a distinguished road
haha yeah but what ever, thanks for the pic
Old 10-22-2010, 06:02 PM
96DodgeRam1500's Avatar
96DodgeRam1500 96DodgeRam1500 is offline
Vehicle: 1998 Dodge 2500 4x4 Sport
96DodgeRam1500 is on a distinguished road
no problem
1998 Dodge Ram 2500 Sport 4x4. 360 all stock. Leveling kit with 315s.
Old 12-01-2010, 07:41 PM
weeder's Avatar
weeder weeder is offline
Vehicle: 1997 Dodge Ram
weeder is on a distinguished road
I have a skyjacker 4" on mine with 33x12.50 and if i wanted to i could squeeze 36's but they would scrub. Im looking for a set of 35x14.15x15 for it right now.
But im shure you could run35's with a leveling.
Old 12-05-2010, 03:05 AM
Skull1313's Avatar
Skull1313 Skull1313 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SRT2
Skull1313 is on a distinguished road
Send a message via Yahoo to Skull1313
Default A little help here also.
I'm not trying to jump on your thread but I'm interested also in the lift kit. I have a 01 and for the life of me(there is no badge when I got it) I cannot tell if it is the factory off road package. I have 33x12.5x17 pro comps with no rubbing. I want bigger. Any ideas. Suggestions on how to tell?
Old 12-05-2010, 11:35 PM
Is your truck all the same color? Like is the grill, bumpers, and tail lights all the same color as the truck?
Also, do you have a 4WD or 2WD?
If your truck is all the same color then you have the Sport Package and Ive seen them sitting a little higher than stock. But the standard 4WD also sits higher than stock. And is your truck sitting level or does it have a slight rake?
Old 12-06-2010, 04:09 PM
Skull1313's Avatar
Trim Level: SRT2
No actually the grill is chrome along with the bumpers. I had a sport years ago 99 actually and it was all black. This is not a sport model. Its 4wd. It actually had what I believe to be factory blocks on the rear axle. The front sits a little lower than the rear. Maybe by about 1/2 to 1 inch. Its not very noticeable. I looked on the front spring perch for a leveling kit and there is nothing. Would the vin number tell me anything? Thanks for all your help.
Lost in Dodge lift land.
Old 12-06-2010, 06:56 PM
Yea the VIN should give all the specs on your truck. LMC Truck will have all the info to read your VIN from your trim down to where your truck was made. not sure what stock ride hight on a 4x4 is but a 2WD is 3" in the front and 5" in the rear... from top of tire to fender..
I just had a set of 35" BFG Mud Terrains on my truck and I have a 2WD with just a 1.5" coil spacer. Obviously it was gona scrub but not as bad as I thought. I got a pic on the 1st page of this thread. I did have to cut a bit of the plastic fender liner but I didnt have much of a lift to clear them completely. You should be able to get 35s under yours with no problem and you could even through a leveling kit if you wanted to.
