2007 17" alloys fit on a 2004 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-27-2010, 08:01 PM
r1500w2004's Avatar
r1500w2004 r1500w2004 is offline
Vehicle: 2004 1500 4wd quad cab
Color: silver
r1500w2004 is on a distinguished road
Default 2007 17" alloys fit on a 2004
Will wheels from a 2007 fit on a 2004? My truck came with steel 17's with chrome "overlays" is the best way i can describe it and they are trashed...it looks like the previous owner left wheel acid on them for way to long..I have a line on a set of 17" wheels off a 2007 for pretty cheap and might go for them until i level it....
thanks for any info
2004 4.7 6000 hid headlamps, airraid cai and filter, bed cover, 2 inch crank on torsion bars,tint
Old 09-27-2010, 08:05 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
They'll fit just fine. All half-ton's have the 5x5.5 bolt pattern, and the 17's I think are the same size. You should be good to go!
Old 09-28-2010, 08:33 PM
r1500w2004's Avatar
Color: silver
thanks..did you crank up your torsion bars to level your truck or buy keys..i have been on this site and others trying to get a lot of different opinions and am thinking i might just crank mine up for now and save up for a 4 inch kit down the road..
Old 10-02-2010, 02:48 PM
jcasey10's Avatar
Rep:869
I haven't done the torsion key. I like the way my truck sits right now.
Old 10-02-2010, 03:04 PM
You just need to verify the bolt circle on the newer wheels. They should be a 5 lug X 5.5" bolt circle. It might be a good idea to also measure the offset just to make sure they don't rub on the inside or stick outside the wheelwells. Here's the specs you should be looking at:
• Lug Pattern: 5 on 5 1/2
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
• Fits 94 and up 1500 trucks
This is a 2003 spec but should be applicable to yours as well.
