Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 09-27-2010, 08:07 PM
racer965 racer965 is offline
racer965 is on a distinguished road
Default Wheel Bearings gone bad need some advice.
Hey guys I recently found out my front left wheel has a bad wheel bearing. Its the bearing that is behind the hub like the bearing closest to the pumpkin. My question is can u change just the bearing or do u have to buy the hub with the bearings already installed. Thanks.
Old 09-28-2010, 01:35 PM
Resident Technician
Rep:1915
The hub bearing is serviced as an assembly.
Old 10-23-2011, 05:02 PM
heff heff is offline
Vehicle: 2004 Ram 1500
heff is on a distinguished road
How easy is it to replace a front wheel bearing on a 2004 Ram 1500 4x4 Was hoping to to it my self, I have replaced brake pads and rotors on the truck, but have not done wheel bearings on a car since the old days when you re-packed them when you did a brake job.
Thanks in advance for your help.
Old 02-16-2012, 01:01 AM
Bennett15's Avatar
Bennett15 Bennett15 is offline
Vehicle: 2006 dodge ram 1500 big horn
Trim Level: SLT big horn
Rep:45
Bennett15 is on a distinguished road
hub replacement is a pretty extensive job to be honest. jack truck up take wheel,caliper, and rotor off. then you gotta take axle nut off which is torqued to 175ft/lbs suggest an impact for this. then there is 3 bolts on the back side of the hub to access them without poping ball joints turn the wheel to full lock one way take out bolt then other way for the next bolt may have to push axle in to get socket on then when all bolts are out its just a splined hub so beat it off
5% tint, 35% Windshield, Airaid intake, Super 44 exhaust, DiabloSport inTune, 24" Strada Wheels, Bakflip G2 tonneau, Groundforce 2/4 lowering kit, Bilstein shocks, Roll pan, Upper and Lower Eylids, Cross drilled rotors, LED interior, 12k Headlight/Fog HIDs, Recon Tailights, Kenwood Navi deck
Old 03-18-2012, 05:59 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I've done quite a few of 'em. The only difference in advise I have is to do the axle nut first if possible, leaving the front wheel on to hold it still.
Old 03-18-2012, 10:05 PM
bighemi04's Avatar
Vehicle: 2014 Charger RT AWD
Rep:623
do yourself a favor and pay someone to replace it. my front passenger hub assembly snapped off of my truck while i was driving. as a matter of fact both of my front hub assemblies have went out
