Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 11-24-2011, 02:31 PM
doc hays doc hays is offline
Vehicle: 2003 dodge ram 2500
Trim Level: lt
Color: silver
doc hays is on a distinguished road
Default Pinion Seal Leak
I noticed an oil leak from my 2003 dodge ram 2500 rear end. Did some checking and found it was coming from the pinion seal.I was told I'd need a seal and new torque pinion nut to do this job.
Are there anymore secrets I need to know before I tackle this job?
Tools needed and sizes would be a great help. Thanks,Doc
Old 02-11-2012, 07:23 PM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
I had my front diff pinion seal fixed under warranty. Sorry, I dont know much about it.
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
Old 02-11-2012, 08:11 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1276
It's been quite a few years since I've had to do a pinion seal. You are correct in that you will need a new seal and crush sleeve. If you can get your hands on a manual for your truck get the torque spec for setting the crush sleeve and procedure for checking backlash. It's not a tough change or fix however it does need to be done correctly or you stand the chance of chewing up the diff.
Big Red my old 2011 Sport
Old 02-13-2012, 07:16 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Another option, and if ever faced with a leaking pinion seal, the route I will take. The dealer charges around $100 or so to do this. To me its worth it to not lay on my back fighting with breaking that nut loose and trying to keep everything just right.
Sure it'll suck, but it'll make you a man
Old 02-14-2012, 11:29 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
I find that if you put a socket wrench or breaker bar on the nut and chock the wheels and put the park break on you can loosen the nut by putting a floor jack under the handle of the wrench or bar and jacking up the handle. The best part is you can use this to do the reverse procedure to tighten the nut and the best part is that you can with the jack tighten it very slowly, if you use a traditional impact gun you risk over tightening. You don't have to replace the crush sleeve but it's certainly recommended. As long as the pinion's rotational torque comes out around 15-20 inch lbs your alright. Of course that torque is measured without the axle shafts installed.
