Old 06-14-2010, 09:45 PM
sablefish's Avatar
sablefish sablefish is offline
Vehicle: 2013 ram sport
Color: red
Rep:78
sablefish will become famous soon enough
Default air pressure?
how much air psi are you running in the tires on your trucks? I just got some procomp extreme mt's 35 x 12.5 x 20 and am not sure what to run them at.
2013 ram sport, 8 speed. pace edwards full metal jack rabbit tonneau, bed slide 1500cg bedslide, husky weatherbeaters
Old 06-14-2010, 09:47 PM
Rep:1915
How many plys are these tires?
Old 06-14-2010, 10:52 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
It depends, i run mine at 40 PSI, 8 ply tire, usually on the 1500's the plac says 35, but that is also with a passenger tire!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-14-2010, 11:00 PM
sablefish's Avatar
Color: red
Rep:78
They are load range E, 6 ply tires. Says 65 psi max on the side wall. I bought them used with 95% tread left on them, they are mounted on a nice set of chrome eagle alloy rims. 2 tires have 55psi and the other 2 are at 65. i never ran 35" tires before so I would like more info of were to run them psi wise. Even 55psi seems high to me but I dont want to run them underinflated. Thanks
http://www.offroaders.com/tech/AT-MT...-Xtreme-MT.htm
Old 06-14-2010, 11:03 PM
sablefish's Avatar
Color: red
Rep:78
My truck came with 17" tires and rims and the door plac also says 35 psi
Old 06-15-2010, 06:14 PM
Ruffian11's Avatar
Rep:140
A load range E tire will be a 10ply tire, Load range D 8 ply and Load range C 6 ply! so you have 10 ply tires not 6, as for pressure that is pretty high especially if your running empty all the time, will give a harsher ride! Being your running a 1500, i would say 35 all the way around would not be a problem, if your start towing, or hauling heavy loads then i would increase the pressure
Old 06-15-2010, 06:38 PM
Rep:1915
I pretty much agree with Ruffian. Just keep an eye on your wear pattern and adjust pressures accordingly.
Old 06-15-2010, 09:05 PM
ScatPak07's Avatar
Rep:970
I have 36-38psi in my BFG All-Terrain KOs. They are 33" high not sure about the ply though. My psi was at 43 in the rear but I saw the wear on the outside a bit and brought it down. I saw the wear when I drove into my buddies shop and it was clean with some dust. You could see the way it was wearing. I think anywhere between 35-40psi should be alright
Old 06-16-2010, 04:32 PM
sablefish's Avatar
Color: red
Rep:78
Thanks, I dropped the psi in all to 40. good starting point and will go from there
Old 09-28-2010, 10:36 AM
03 Hemi's Avatar
03 Hemi 03 Hemi is offline
Vehicle: 2003 Dodge Ram
Rep:13
03 Hemi is on a distinguished road
I'm bringing this thread to life again lol. I just put larger tires on my tuck, 285/70/17. They are BFG AT's and it says inflate to 65 psi, should i still run between 35-40 or closer to 65? I know on my Jeep Wrangler I always ran 5 psi lower than what they called for.
Josh
2003 Dodge Ram 1500 QC, 5.7 Hemi
