Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Place your Ad Here!
Old 09-30-2010, 08:24 AM
Resident Technician
Rep:1915
Glad to help. Congrats on the newborn.
Old 12-22-2010, 10:37 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
The diagram you provided is bieng reviewed tonite so that my buddy will swap that out too. Just wanted to update you cuz i did say ill keep you posted lol. Thanks again RAMTECH. fyi replacment part will run me $52.00 plus tax. Ill post tomorrow the results.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 01-24-2011, 04:37 PM
CanuckHRAM's Avatar
CanuckHRAM CanuckHRAM is offline
Vehicle: 2011 Ram Quad Cab 4 x 4
Trim Level: SLT Outdoorsman
Color: Deep Water Blue Pearl
CanuckHRAM is on a distinguished road
Hi Raming It,
Just wondering if you were able to replace the resistor? I believe I have the same problem - my blower only blows low (across all settings except high) and then the Highest. Just started doing this.
Thanks,
CanuckHRAM
Raider Phantom Topper, K&N Drop-In Air Filter, Vent Visors, SmittyBilt Light Bar & PIAA Lights
Old 05-20-2011, 07:20 AM
RAMING IT's Avatar
Rep:65
Post
Yeah all fixed the connector was a bit melted, RAMTECH was right on the money.
Old 06-21-2011, 10:16 PM
LeTempt LeTempt is offline
Vehicle: 2002 Dodge Ram
Color: Blue
LeTempt is on a distinguished road
Had the same issue on my 2002 Ram last year. Removed the 2 screws on the resistor and leaves fell out of the hole. One of the metal conductors came un-soldered from the resistor. Pulled the electrical plug, took the resistor in the house (to the dining room table), and re-soldered the strap. Figured I had nothing to loose so I gave it a shot. Took me longer to warm up the soldering iron than it did to make the repair. Cleaned out as many leaves and debris as I could and reinstalled the resistor. Worked like a champ. I know the part is probably living on borrowed time, but if it goes out again I know exactly where to look.
Jeff
Old 06-22-2011, 07:56 AM
RAMING IT's Avatar
Rep:65
There you go easy fix.
Old 05-21-2017, 11:52 AM
Bhmendenhall Bhmendenhall is offline
Bhmendenhall is on a distinguished road
Perfect answers. Replaced mine in ten minutes not including vacuuming out the duct. Works great.
