Place your Ad Here!
Old 09-28-2010, 03:39 PM
tomsRAM1500 tomsRAM1500 is offline
tomsRAM1500 is on a distinguished road
Default Poor Bluetooth connection - Where is the Bluetooth antenna?
I seem to have a problem with the Bluetooth connection in my Ram. I have the Uconnect and have paired my phone. When I use the Uconnect, I leave the phone in the center console. The bluetooth connection intermittently cuts out to the point that it's a hassle to use. I currently have the Samsung Fascinate on Verizon but have noticed it with other devices as well (all Verizon). Anyone know what to do to fix the problem or know where the bluetooth antenna is so I can put the phone right by the antenna?
Thanks
Old 09-28-2010, 04:01 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
More often than not the cutting out is not the bluetooth connection. Its the phones signal with the network.
Nice thing about bluetooth is its an either/or thing. It either works or it doesn't. Is your phone on the Uconnect compatible list? If not, you'll only get basic capability (make and receive calls).
Brian:
Old 09-28-2010, 04:25 PM
Raptor1000R's Avatar
Raptor1000R Raptor1000R is offline
Vehicle: 2010 Ram 1500 4x4 Sport Crew
Trim Level: Sport, buckets, RER
Color: bright white
Raptor1000R is on a distinguished road
I have had the same problem, but it only is weak approx. 5% of the time. I deleted my phone from the pairing list, then paired again. It seems to work better. I didn't have this prob. at all on my `07 SRT Jeep. Makes you want to put the phone infront of a smoking tire though!
2010,15004x4,Hemi,Sport,White,Crew,CAI,Predator,Li ne-X,Truxedo Lo Pro,2"level kit,PE Powergate
Old 09-28-2010, 05:06 PM
Color: RootBeer
Rep:1287
Forgot to ask, is the phone inside the center console or outside it? If its outside sitting in the tray then you have other issues. If its inside the console, take it out and see what happens.
Brian:
Old 09-28-2010, 06:05 PM
1badram's Avatar
1badram 1badram is offline
Vehicle: 2009 dodge ram 1500
Trim Level: Bighorn
Rep:22
1badram is on a distinguished road
I can connect to Uconnect with my iPhone from 45 feet away outside the truck so it shouldn't be a problem in the console
2009 Dodge Ram 1500 SLT Bighorn 4x4 5.7l hemi
Old 09-28-2010, 07:19 PM
platinuminjected's Avatar
Rep:713
i would think its a problem with the network or something
Old 09-28-2010, 07:24 PM
I have the bucket seats with the shift level in the center, not on the steering column. When I have it connected, I leave it in the open compartment right next to the shifter, not inside the console itself.
I'm going to call the UConnect customer service tomorrow.
Thanks
Old 09-28-2010, 10:51 PM
Rep:2910
i would call your phone company
if you are using a APPLE product, like the Iphone4, thats your problem, cuss them out in a 5 page email, call them every damn name in the dictionary
Old 09-30-2010, 01:19 PM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
i would try to pair it again, i have a verizon blackberry and have never had connection problems except when i have a low signal already due to the network being out of range. the only real "problem" i have is the uconnect shows a lower battery strength than what is on my phone, i just plug it into the battery charger and everything is fixed.
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 10-01-2010, 05:54 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
One thing you have to keep in mind if your calling uconnect. The U-Connect customer support only handles non-navigation radios. The U-Connect in the My-Gig nav is a completely different u-connect and it is handled through chrysler and not u-connect. Not to mention the u-connect customer support wont ask if you have a nav radio so they will feed you information that is not correct to the nav radio. One other fact, the non-nav radios have a different compatability list then the nav radios.
