Old 09-28-2010, 07:31 PM
oaklandopen oaklandopen is offline
oaklandopen is on a distinguished road
Default reverse fuse, or whatever wire i need...
can someone help me find either the fuse that operates the reverse lamps? im hoping that they are not operated via computer module and that there's an actual physical wire that is fused and switched running straight towards the reverse lights
im trying to hook up a reverse camera, but i pretty much need to find the reverse wiring i need in the engine bay with the fuse panel or im gonna be running a wire allllll the way back to the bulbs. i've already seen that the B+ wire is white/pink-stripe. damn fuse panel is unclear
my 1st post ftl
Old 09-28-2010, 07:34 PM
actually...upon inspection, i think i may have found a connector point behind the driver's side wheel well that has the same color wire i can tap into. i also see a plug that should go right to the foot area inside the cabin
