Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 09-28-2010, 10:11 PM
TVDOC TVDOC is offline
TVDOC is on a distinguished road
Default Rough running hemi leads to other problems
2010 Hemi with less than 20k miles. 2nd time it is in the shop with the same problem.
Engine began running rough and check engine light came on solid. Took it to the dealer, they replaced a plug they said was defective, and sent me on my way. Ok for 3 weeks. Then, it began running rough again. Check engine light again, especially under a load or when accelerating...just like the first time. Now they said it isn't a plug but they are pulling the heads to look for a sticking valve. They are offering a used car as a loaner. They estimate they may need it for 7 to 10 days! Are you kidding me?
Sound familiar to anyone? Comments? How should I proceed with this and how long should I play along? Any recourse with Dodge yet?
Old 09-28-2010, 10:14 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Play along? Sounds to me they are doing the right thing and even went one step further by giving you a loaner.
This is what warranties are for. Not everything that comes out is perfect.
Brian:
Old 09-29-2010, 01:03 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Not a perfect solution, but like RB said, I think that they are doing the right thing. If you have the easy care you could get a rental, but IIRC they only pay $30 a day towards a rental.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 09-29-2010, 03:30 AM
thewagon thewagon is offline
Vehicle: 2010 RAM 1500 QC BigHorn
Rep:35
thewagon is on a distinguished road
Isn't one more try at repairing the same problem justify a lemon law refund? Hope it works out for the better
Old 09-29-2010, 04:24 AM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
Brian what is this door seal protection in your sig?
Aepowell Sherman,TX.
Old 09-29-2010, 08:15 AM
No and at this point, it's not clear that the two issues are connected. There is more than one reason for a rough running engine.
There's a problem for sure, TVDOC, but it may have been a manufacturing QC problem and that's what warranty is for. I have a bit of a problem with the 7 - 10 days thing unless that includes getting the right parts and fixing the problem. It is excessive for diagnostic time.
Old 09-29-2010, 08:46 AM
DBryant DBryant is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT, Big Horn
Color: Crimson Red
DBryant is on a distinguished road
Had a check engine light with rough running and they kept it 10 days. Replaced some spark plugs and other things, didn't work, and finally the computer. That fixed it. Gave me a loaner, (used car) dirty and old, wife complained, and we got a new one from Enterprise. Dealer had to order the parts, took several days to get them.
Old 09-29-2010, 12:52 PM
inkdemon's Avatar
inkdemon inkdemon is offline
Vehicle: 2015 Dodge 1500
Color: Vivid black
Rep:37
inkdemon is on a distinguished road
Send a message via AIM to inkdemon Send a message via Yahoo to inkdemon
good luck on a fast and correct fix!
Old 09-29-2010, 04:52 PM
Raptor1000R's Avatar
Raptor1000R Raptor1000R is offline
Vehicle: 2010 Ram 1500 4x4 Sport Crew
Trim Level: Sport, buckets, RER
Color: bright white
Raptor1000R is on a distinguished road
if you need a truck, I'd make sure you let them know that's why you bought a new truck, not a used loaner CAR
2010,15004x4,Hemi,Sport,White,Crew,CAI,Predator,Li ne-X,Truxedo Lo Pro,2"level kit,PE Powergate
Old 09-29-2010, 09:30 PM
An update to my original post...
OK. I'll stand down but just a little. This IS what the warranty if for so I'll let it run it's course. Got the call today that the exhaust valves in Cyl 1 & 3 are badly 'burned' and need replaced. Also, the cylinder head needs sent out and machined. Dealer is going to replace exhaust and intake valves in both cylinders and send the head out to a local shop. Problem is they need 8 to 10 days just to get the parts from Chrysler! Really, no parts in stock in the US?
My questions are: How does a 20k mile engine have burned valves and cylinder heads? How can I have enough confidence in this engine to keep it past the warranty period?
