Dodge Ram Decals
Old 09-30-2010, 06:11 PM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
Originally Posted by Wildcat View Post
So In theory, if you owned more than one ram, could you make the same fob work in both? If truly it is based on the truck recognizing the fob.
Originally Posted by LBZ HEMI View Post
Nope once it's been programmed to one truck it can never be use for any other truck
Originally Posted by SvB4EvA View Post
Why not? I was under the impression the truck was programmed to the fob.
I would like to see this tried. As per my original post, the fob should be able to start any truck it's programed too. The passive transponder should react the same way to every truck regardless of programing. The trucks just needs to be programs to accept the transponders code. There is no reason one key could not therefore be used to start multiple trucks if each truck was so programed.
I'm talking now about the key in ignition type of thing, not remote start or anything. Likewise I don't know about remote doors, windows, etc. These features are going to transmit on a particular frequency and perhaps there is a locking mechanism that once it is set it can't be unset.
I am basing all these suppositions on the idea that Chrysler is doing this the same way most vehichle manufaturers have been going things for about 10 years. It is of course also possible that they changed the mechanism with the gen 4's and none of this applies anymore.
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 09-30-2010, 06:39 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
I agree other wise they couldn't give you a new key if it were lost. They have to have a way to program the new key
Old 09-30-2010, 07:35 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
In theory the key/fob can be used on multiple trucks. But those trucks ignitions would have to be programmed to that key/fob. This is where the problem would likely come up as the truck's system may not allow such programming.
Brian:
Old 09-30-2010, 08:00 PM
GPSHSLAX's Avatar
Trim Level: ST 2X4
Rep:236
... but how would the truck know if the fob had already been used on another truck?
I realize that almost sounds sarcastic but I don't mean it that way (this time).
Old 09-30-2010, 08:05 PM
Color: RootBeer
Rep:1287
I think it would be in the software the dealer uses to do the programming. Seems to me it would recognize the key is registered to another truck and there might be some kind of block built into it to not allow it.
Again, this is all theory.
Brian:
Old 10-01-2010, 12:03 AM
GPSHSLAX's Avatar
Trim Level: ST 2X4
Rep:236
I'm pretty sure there is a procedure for prgraming them yourself. Assuming you already have a working key (I know ford requires 2 workings keys for theirs). In this case there is no software required at all. It's one of those turn the ignition off and on three times, then hold your nose and honk the horn type deals. Maybe we need Randy to chime in here with some dealer type info.
Old 10-01-2010, 01:01 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Wow, I didn't realize my question would spark such intrigue. Now I REALLY want to know, even though I only have one truck.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 10-01-2010, 02:56 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
I have a friend that has both a Ram and a 300. He asked the dealer to program his keys so that he would only have to carry one set. When they tried to program the second vehicle to the Fobic, apparently the programmer said it couldn't do that as the Fobic was already programmed to a vehicle.
I stand to be corrected, but it is my understanding that although the Fobic is passive, part of the programming procedure writes to (modifies) the Fobic, and I understand that this can only be done once. If this is the case, that would explain why it cannot be programmed to more than one vehicle, and why it can't be de-programmed then re-used on a different vehicle.
brad
Interested in one of my mods?
