Tow/Haul mode or no? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 09-29-2010, 07:15 PM
SvB4EvA's Avatar
SvB4EvA SvB4EvA is offline
Vehicle: 2010 RAM 1500 4x4
Color: Inferno Red
Rep:25
SvB4EvA is on a distinguished road
Default Tow/Haul mode or no?
Looking for info about having tow/haul on or off when racing. Opinions? I read that when in tow/haul the transmission will hold a gear longer before shifting, but does it do this while WOT any way when not in tow/haul?
-Steve
Old 09-29-2010, 07:26 PM
onebadbee's Avatar
onebadbee onebadbee is offline
Vehicle: 2005 dodge ram
Trim Level: rumblebee
Color: yellow
Rep:16
onebadbee is on a distinguished road
it dont affect my times at all
how fast do you think your running you dont want to shift into the 4th at the track
so what i do when i get into third and above 5 rpm i drop it back down into 2nd and it locks it into the third
12.86 1/4 N/A 1.69 60FT N/A no heads no nitrous no power adders
Old 10-03-2010, 08:40 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
you have a hurst shifter or the regular shifting
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 10-03-2010, 09:32 PM
SvB4EvA's Avatar
Color: Inferno Red
Rep:25
if you mean the floor shifter, yes
-Steve
Old 10-09-2010, 09:28 PM
Trim Level: st
Color: silver
Rep:68
yes i meant floor shifter
Old 11-22-2010, 01:01 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
So, what was the conclusion to this? Is there any gain to using Tow/Haul mode, or even OD Off mode? Onebadbee said now, however he also has done some work to his engine...So for a completely stock Ram, with maybe a CAI and Exhaust only, will switcing to either of these modes give a little gain in 1/4 time? I would have thought personally that OD Off would due to the slighty higer shift points, and no "lag" from switching to 4/5 gears...
Old 11-22-2010, 01:15 PM
Rep:2929
i'm not a racer, but, i would use tow/haul mode & pull out the air filter when at the track
if the trans hits 5th gear, on the track, you will lose time, not gain, maybe they were correct saying that going into 4th could do the same
Old 11-23-2010, 12:25 AM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
you wont get near 4th or 5th in a 1/4 mile......not without some really low gears....
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 11-26-2010, 02:57 PM
combatsp's Avatar
combatsp combatsp is offline
Vehicle: 2009 Dodge Ram
Trim Level: Crew Cab, Sport, 4x4
Color: Stone White
combatsp is on a distinguished road
I race my 4th gen Ram. I found it better to run with Tow/Haul on. I may be mistaken but it utilizes the 2nd prime before 3rd gear. My truck, with the 3.92 gears, shifts from 2nd to 2nd prime at about the 1000' mark and still pulls hard. When it shifts from 2nd to 3rd it falls on it's face. Our trucks have 6 forward gears but do not use the 6th gear(2nd Prime) unless it is in Tow/Haul or Manual shift mode. I wouldn't shift manually unless you have a tuner that will allow you to change the shift points to a higher RPM. Tow/Haul On = 1, 2, 2prime, 3, 4 Tow/Haul off = 1, 2, 3, 4, 5. You only need the first 3 gears for a 1/4 mile run. If I am mistaken someone please correct me. Thanks.
2009 Dodge Ram, Sport, Crew Cab, 4x4, 3.92, Ramboxes, Line-X, Amp Research side steps, Superchips
Old 11-26-2010, 03:01 PM
I agree with that ^^^^ and don't know that O/D off would change the gear multipliers much anyway.
