engine wont idle and dies after start - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 09-30-2010, 12:06 AM
RamRunner4x4's Avatar
RamRunner4x4 RamRunner4x4 is offline
Vehicle: 1998 dodge ram 1500
RamRunner4x4 is on a distinguished road
Default engine wont idle and dies after start
So just recently my truck decided that it wanted to act up. i had been feeling my engine kinda sputtering like it wanted to die the past couple of days then today when i started it up the RPMs dropped immidiately and i had to accelerate to keep it running and then the next time i started the truck the engine died almost instantly after it started. now it wont idle at all and just dies. i was told that it cold be my IAC valve i plugged a code reader in and the only things that come up are p0443(Evaporative Emission Control System Purge Control Valve Circuit) and p0302(Cylinder #2 Misfire) but those have been on there long before this had been happening. anyone have the same problem or know anything?
Thanks
If You Aint First, Your Last.
Old 09-30-2010, 12:15 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
We just had a member here with similar problems and he replaced the IAC which he said fixed his problem.
Not saying it will in your case but its worth a shot.
Brian:
Old 09-30-2010, 12:24 AM
yeah i just started reading previous posts and found a couple that say i should clean it and hopefully it fixes the problem. ill do that tomorrow and hope it works! thanks
Old 09-30-2010, 08:27 AM
Resident Technician
Rep:1915
Is the P0302 active or stored?
Old 09-30-2010, 10:41 AM
i think its just stored because i have fixed it, the wires were damaged pretty bad. it seems fine now
Old 09-30-2010, 11:37 AM
Resident Technician
Rep:1915
You need to clear all the codes. If you haven't fixed the P0443 it will obviously come back though.
Old 09-30-2010, 11:59 PM
so i cleaned my IAC and my truck is running fine, also decided to get a new OPTIMA red top battery today to replace my really old battery. also cleared the cylinder 2 misfire code but the other still remains.
Old 10-18-2010, 09:55 PM
coreyCK coreyCK is offline
Vehicle: 1999 RAM 2500 4x4 Ext cab SB
coreyCK is on a distinguished road
My truck did the exact same thing last night, it died at a red light and wouldnt start. When I jumped it, it would not hold a charge, it would not idle and I had to keep it above 2000 rpm or it died.
What is this IAC you speak of?
thanks.
Old 10-18-2010, 10:58 PM
It was my idle air control valve. It pretty much let's in air while your throttle body is closed so your truck will idle from what I understand. I'm in no way a tech but I used google and looked all over these forums and decided that was the problem so I took it off and pushed the valve in all the way. After that I put it back together and it seemed to have worked because my truck was back to normal. Try that and see if it helps. Idk about your vehicle but it was located on the back of my throttle body, if you have a stock air box you may have to take it off I'm not sure because I have an aftermarket cai. Good luck and let me know how it goes I hope it helps.
Old 10-21-2010, 01:14 PM
Me and a buddy where screwing around with it and he suggested that it could be just the alternator. So we swaped it for a new one and so far its been holding a charge and running good.
thanks for the info though
