Old 09-30-2010, 09:56 PM
gonzo1's Avatar
gonzo1 gonzo1 is offline
Color: Mineral Gray
Rep:17
gonzo1 is on a distinguished road
Default Need advice!!!!
I have the mcgauphys 2-4 drop with the spindles and hate the way my front wheels stick out!! They stick out about one and a half inches on both sides. The backs are great and flush. Also the wheels are 24x9.5 inches all the way around with a 15mm offset with 295/35/24 on all 4 corners. Now my question is if I put the factory spindles back on and then put a 2inch drop front coil spring on it will it get my front wheels pulled in like the rears are am I wasting my time and money trying this? I have read from some of the guys on here that the mcgauphy spindles do that but the coil spring kit doesnt. Is this true?
Old 10-01-2010, 02:59 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I have never heard of anyone complain of the front wheels sticking out with the factory spindles. From the factory, the front and rear tires track the same, and even with the altered geometry of a 2" drop, I can't see how it could protrude by any more than a fraction of an inch. As long as all your rims are the same, the front/rear tracking should be in line. I wish I could say definitively, but would be real surprised if there was any noticeable protrusion with the factory spindles.
brad
Interested in one of my mods?
Old 10-01-2010, 03:30 AM
skeezy1's Avatar
skeezy1 skeezy1 is offline
Vehicle: 1996 Dodge Ram Sport
Rep:92
skeezy1 will become famous soon enough
the offset on ur wheels are too low for a 9.5 inch wheels. it will be the same on a stock spindle. you would need a 30-45mm offset or a 8 inch wheel to bring urs in.
http://i382.photobucket.com/albums/oo266/skeezy1_2008/The%20ram/DSC04370-1-1.jpg
Old 10-01-2010, 09:17 AM
You could try the spindle thing but I don't think it will work.
The best solution is to change the wheel offset as suggested.
Old 10-01-2010, 11:40 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
The issue is complicated, yet simple. The arc of travel is the same, just 2" higher. So it really isn't sticking out more, it will give that appearance however, it also is more likely to scrub. I run drop spindles on both my vehicles right now, both times it made good fitting wheels fit worse.... I will just use a ziz wheel on the fender lips to fix my issues, but if you bought wheels and they didnt know it'd be dropped, you may have a 4x4 truck offset where the can and will stick out for the big truck look. Look for a 45mm offset and you'll be good.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 10-02-2010, 03:46 AM
gonzo1's Avatar
Color: Mineral Gray
Rep:17
Thanks for the advice! But got my springs on the way and I hope that helps! If not, im NOT putting the McGauphy spindles back on. I will leave the springs in and hope that at least pulls the top of the tire in some. By the way i will be selling the spindles if anyone is interested. Tried to post in the for sale section but it wouldn't let me.
