Old 10-01-2010, 12:36 AM
dirty97ram dirty97ram is offline
Vehicle: 97 ram 1500 ext cab short bed
Color: bedliner
dirty97ram is on a distinguished road
Question auto to standard swap????
i have a 97 1500 ext cab short bed 5.2 auto an my trans is starting to go bad i was wondering if anyone has done a 5 spd swap? if so how hard was it? is it worth doing instead of having the auto rebuild? an what all would i need to do it? any help would be great.
thank you guys in advance
Old 10-01-2010, 12:52 AM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
There has been some talk of swapping in manual tranny's on the 4.7 board. Nothing with the specific details your asking for but it might be a start.
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 10-01-2010, 12:56 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Way more trouble than its worth. Swapping manual to auto is a piece of cake. The other way however.....
Brian:
Old 10-01-2010, 01:13 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Yeah, you're looking at cutting a hole in your floor board and a new steering column. Just a lot of work that's super tedious.
Old 11-15-2010, 01:35 PM
moparmud89 moparmud89 is offline
Vehicle: 1994 ram 4x4, 1974 power wagon
Trim Level: laramie slt
Color: red 94 green 74
moparmud89 is on a distinguished road
New steering column? Is there a difference or do you just mean to do away with the auto shifter? I'm interested in doing a swap on my 94 4x4 and i'm not averse to cutting the floor and will just leave the auto shifter flopping. Besides the difference in the neutral switch (i can do the basic changes in the wiring) what would make it overly difficult? I want to find a wrecked truck to take the tranny, case, and shafts out of
Old 11-15-2010, 02:46 PM
Color: RootBeer
Rep:1287
Here's how it breaks down in my head. First off, removing the auto shift handle is a piece of cake, no new column needed. Now for the fun stuff.
1. New trans
2. Clutch
3. Bell housing
4. Install clutch master cylinder (if its hydraulic)
5. Install clutch slave cylinder (if its hydraulic)
6. Run lines for clutch fluid
7. Cut hole in floor of truck for shifter
8. Install trans brace on frame
9. Remove brake pedal.
10. Install clutch pedal/brake pedal combo (they are usually on the same shaft, not independent but I could be wrong)
11. New drive shaft and u-joints
12. Possible new transfer case or modification to the existing one.
That's about all I can think of at this point.
Brian:
Old 11-16-2010, 11:40 AM
ok so no go without a donor truck. May be better to just build my 518 or find a torqueflite
Old 11-16-2010, 05:52 PM
Color: RootBeer
Rep:1287
Seems to me that's your best option. If you were going from standard to auto, it would be a piece of cake.
Brian:
Old 01-09-2011, 09:32 PM
babetheox777's Avatar
babetheox777 babetheox777 is offline
Vehicle: 2009 ram 1500
Color: blue
Rep:21
babetheox777 is on a distinguished road
i was thinking of doing that exact same thing, sawping out my weakaning auto for a 5 sp. but im glad i looked at this thread, thanks for the info, im buying a remanufactured or new.
Old 01-11-2011, 04:49 AM
keegles's Avatar
keegles keegles is offline
Vehicle: 1998 dodge 1500
Color: driftwood
Rep:19
keegles is on a distinguished road
im thinkin about swaping my 5speed out aand putting in an auto. anyone have a write up or know what all id need to swap, aside from trans, colomn, and drive shaft? would i have to swap out the computer?
