Place your Ad Here!
Old 10-01-2010, 07:27 AM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
Default Why a 180 deg stat?
What are the advantages of a 180 deg stat? I know it starts to open sooner there fore the engine is being cooled sooner but to what advantage, also here in Nova Scotia Canada winter can be very cold will this hamper the heater capabilities at all?
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors, Bully Dog GT Platinum.
Future Mods: What ever I can sneak by my wife.
Old 10-01-2010, 07:40 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
It's more advantageous if you start upgrading for performance. With the engine running cooler, it helps the ECM really take advantage of the modifying timing from some tuners.
At least that's what I've read...
Old 10-01-2010, 07:59 AM
fuzzycali's Avatar
fuzzycali fuzzycali is offline
Vehicle: 2009 Dodge Ram
Color: Stone White
Rep:63
fuzzycali will become famous soon enough
my heater is still works fine,plenty hot for us down in texas. a 180 t stat does help u gain any Hp, but it helps u never lose the HP u have due to heat soak.an engine will leterally lose HP when it reaches operating temp.having a lower t-stat will prevent this. hope this helps
Have a dropped RAM? Want too? Join our group.
Lowered RAMZ Owners Club/Houston Area RAM Owners Club
At some point the mod list gets too long.
Old 10-01-2010, 08:02 AM
A cooler running engine is a more efficient running engine and it will make a bit more HP. Many folks in warmer climes change them out to keep engine temps down all year round. In colder climes, they may swap them out with a higher temp unit for winter to sustain a higher engine temp.
Old 10-01-2010, 08:07 AM
1RamRunner 1RamRunner is offline
Rep:19
1RamRunner is on a distinguished road
What stat is in it from the factory?
Jim
Old 10-02-2010, 06:57 AM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
203 degree if memory serves correctly.
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 10-02-2010, 09:47 AM
keithh2oskier keithh2oskier is offline
Vehicle: 2010 Dodge Ram 1500 4X4
Color: Inferno Red
keithh2oskier is on a distinguished road
My EVICdisplay temp reads right at 203-204 +- a couple degrees.
Old 10-02-2010, 01:25 PM
mark09sport mark09sport is offline
Vehicle: 2014 Ram RC SB
Color: Blue streak pearl
Rep:18
mark09sport is on a distinguished road
My display read 195 & I pulled the OE stat out & it was the 203.
Now my 180 stat reads about 176.
2014 Ram Express 4x4 Reg cab Short bed 5.7, 8spd, 3.92 gears, Blue streak pearl with all options. 180 T stat, drop in, wrapped intake tube, 24" Mufflex, 2 1/2 lift, Black out ram emblems, Tail light tints.
More MODS to come!
Old 10-02-2010, 03:38 PM
Yup, a 203.
For those of you with electric fans, here's some info that may be helpful.
I swapped out the tstat in my SRT when I first got it. I have two electric fans on the radiator, a low speed and a high speed unit. After dropping in the lower temp stat, I did get a bit of a drop in normal running temp from 199 - 201 down to 185 - 187.
Then I added the Predator so I could drop the control temp for the electric fans to come on, phasing in the low speed fan at 191, high speed fan at 198. Now my temps hang right at 181 - 183 in cooler weather at speed, 189 - 191 in stop and go in the same cooler weather with the low speed fan coming on as needed. In higher ambient temps at speed I'm still around 183 - 185 at speed but the temp quickly shoots up in stop and go, so my high speed fan comes on a bit more often as I get to 198 - 199. I like the way it works so it's something to think about if you have electric fans, a HEMI and a Predator.
Old 10-02-2010, 06:05 PM
Rep:18
I'm surprised that my Ram runs about 179 even with 90 degree temps out with the 180 stat.
More MODS to come!
