Old 10-01-2010, 11:09 AM
sinistersix sinistersix is offline
Vehicle: 2011 Ram Sport
sinistersix is on a distinguished road
Default Got the Ram last night...ipod cable?
I have the 430 radio, it has an ipod button but no ipod cable. Does anyone have the part number and how to install it?
I tried to plug it in USB but it didnt work that way...
Old 10-01-2010, 11:47 AM
ok im retarded nevermind it has the plug, I just needed the cable. I did notice on the upper glove box, there is a little plug in the upper left that goes to a dormant plastic plate, but it has wires, any idea what this is?
Old 10-02-2010, 12:23 PM
bavarian bavarian is offline
Vehicle: 2011 Dodge Ram 1500 Sport
Trim Level: 4x4 Crew Cab Sport
bavarian is on a distinguished road
Default iPod
I had the same problem. There is a USB plug in the glove compartment which will accept the standard iPod cable, except for the iPhone 4. That is a problem since I recently switched from the iPhone 3G. I have contacted Chrysler, uConnect and Apple, and there is supposedly a new software in the works. My best guess is it might be December before we can use the iPhone 4 for music or internet radio--right now even a plain cable won't work from the headphone jack out, never mind streaming audio (A2DP). The Bluetooth phone via uConnect does work, however, but without the phonebook.
If anyone has more information, plus let us know.
Old 10-02-2010, 12:48 PM
The plug in the glovebox sounds like the lead to the iPod connection at the back of the head unit. Some folks have experienced a problem with initialization and charging with new iPods and iPhones. Those with older units have had no problems. I'd try that connection with your unit and check the operation.
Old 10-04-2010, 01:32 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
You can use the double end 3.5mm jack one end in the head phone on iphone/ipod the other end into the truck radio. The USB in that area will keep it charged if you plug that in. Im sure the 2011 are like the 2010 and have the iphone/ipod jack and cable in the top glove box. You can then connect it and run it off the truck controls. It should run of the AUX tab. I have and iphone 4 and it works in my truck. Personally I use the 3.5mm jack that way I dont have to reach halfway across the truck to get my phone.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 10-04-2010, 01:48 PM
No its weird, I found the plug for the ipod, its basically a USB cable. If you open the top glove box and in the upper left you will see a ghost panel with no switch on it, but there are defintely wires running to it...just didnt know what that was.
Old 10-04-2010, 02:03 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Interesting... Mine came with the adapter and the plug-in inside the upper box says iPod on it...
Old 10-04-2010, 02:06 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
Smile
Mine has an actual plug in the upper left corner of the top glove box. My truck came with the cable that plugs into it. The other end is a standard Ipod connector and plugs right into my Itouch. My Itouch charges and I can select songs/albums right from the head unit. My head unit is the Media Centre 130 (RES). I believe the part number for the cable needed is 82210848AB.
sales@revelperformance.com
Old 10-04-2010, 02:08 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Mine says ipod too, however I just uploaded all my music and play it off the internal hard drive...
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 10-04-2010, 02:26 PM
11ramsport's Avatar
11ramsport 11ramsport is offline
Vehicle: '11 Ram 1500
Trim Level: QC Sport
11ramsport is on a distinguished road
I have and 11 sport and I had that same problem I thought you had to order a cable but all you have to do is use a standard ipod cable that comes with every ipod then plug it into the usb in the glove box then wait a few second till the radio recognizes it and it will be under aux. then devices and you can control the ipod directly from the radio.
