Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-03-2010, 10:23 AM
Srd150 Srd150 is offline
Vehicle: 1991 ramcharger,1983 dodge ram
Trim Level: sport, prospector
Color: white , multi
Srd150 is on a distinguished road
Send a message via AIM to Srd150
Default 85 carb issue
i have the 318 w/ the holley two barrel carb. i disconnected the charcoal canister cause it was pulling charcoal up into the carb. if i leave the upper bowl vent open, it does not want to start. if i loop it around to the lower bowl vent it will start, but the moment i give it gas it sputters out. its the only thing keeping it from running. i routed all the vac lines back to OEM per the chart, so i'm good there. my dad plugged the to vent lines individually on my 83 and it ran fine. tell me what you think.
Old 02-23-2011, 10:49 PM
sapper7 sapper7 is offline
Vehicle: 1986 D-150
Color: light blue
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Rep:13
sapper7 is on a distinguished road
I have an 86’ and removed the canister also. I did the same thing and routed the upper side to the lower front vacuum and didn’t have any problems. There is a third line however (at least on mine) from the canister down to the frame and back to the tank. Make sure it’s capped. Not sure if that’s the problem. Also note worthy, I had to adjust the idle and choke idle settings.
