Dodge Ram Decals
Old 10-03-2010, 06:00 PM
White1500 White1500 is offline
White1500 is on a distinguished road
Default wheel offset. 2007 vs 2010
was wondering if anyone knows if the offset and bolt pattern are the same for the 2007 and 2010 1500. thanks!
Old 10-03-2010, 06:19 PM
5 lug bolt pattern I assume?
Old 10-03-2010, 06:30 PM
OK...the bolt pattern for your 1/2T truck (except for the MegaCabs) is 5 X 5.5" or 5 X 139.7mm
I can't find any specs on your stock wheel offset but it's easy enough to measure. Here's a link on how to do that:
https://www.rsracing.com/tech-wheel.html
One other possible source is your local tire and wheel shops. They have catalogs that list stock offset and they have tools to determine the proper offset for aftermarket wheels that may be wider with a wider tire on them.
Old 10-03-2010, 06:54 PM
nice info thanks mad dog
Old 10-03-2010, 06:59 PM
ScatPak07's Avatar
Rep:970
The offset for the 07 Ram is +20. Thats what I was told by a member on this site. The pattern is 5x5.5 as stated above. I had to go through all that too when looking for rims haha.
Old 10-03-2010, 07:04 PM
ok what about my 2010?
Old 10-03-2010, 07:18 PM
Pattern is the same, 5X5.5", as the 2007.
Just can't find a 2010 stock offset specification.
Old 10-03-2010, 07:21 PM
ya ill have to call around tomorrow and find out. i have the stock steelies on my 2010 right now but might get some 2007 stock 17 alloy's and powder coat the black. i like the black and white contrast. thanks again
Old 10-03-2010, 07:22 PM
ScatPak07's Avatar
Rep:970
That sounds like a pretty good idea. Let us know how you make out with everything!
Old 10-06-2010, 12:23 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
It depends on which wheel size you have. The 20's are +19 offset. The 17's, like mine, are somewhere around +24 or +25 is what I have heard (since they are an inch narrower). I think the general backspacing for the 2010 Rams is 5.5" to 5.75". I am going through this same thing right now in looking for some replacements. I intend to go with a 17 or 18 inch rim, with a +10 (or so) offset. That way it will set outward just a little more than stock and will allow room for wider tires without rubbing the upper a-arm. Hope that helps.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
