Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 10-03-2010, 06:33 PM
Mr. Ed Mr. Ed is offline
Vehicle: 2007.5 Dodge RAM 3500
Trim Level: Big Horn Edition
Color: Mineral gray
Mr. Ed is on a distinguished road
Default Oil Monitor Reset Question
Hi, guys! First post on this forum. Here's my question:
I usually do my own oil changes before the oil change warning on the EVIC. When the warning finally comes on I know how to reset it by turning the key to "ON" and pushing the accelerator slowly 3 times within 10 seconds. That part works OK.
What I'd like to know is: if I perform the reset procedure described above BEFORE the EVIC warning appears does this actually reset the oil monitor in the ECM or does the warning have to be visible on the EVIC for the reset procedure to work?
To put my question simply: Does the reset procedure work when the warning on the EVIC is not yet visible? Thanks in advance....
Old 10-03-2010, 06:35 PM
There is no way to prevent the warning from coming on, Ed. You can't reset what isn't on.
Old 10-03-2010, 06:45 PM
Color: Mineral gray
Mad Dog, thanks for the quick reply. From what you're saying, I can't reset the ECM oil monitor before the notification on the EVIC? If that's the case, then the reset procedure works ONLY when the message is displayed?
IOW, there's no sense in trying to reset the oil monitor in the ECM unless the message is displayed?
Hope I made myself clear.....thanks again for the help.
Old 10-03-2010, 07:15 PM
Yes, that is correct. Although, I have not dug deep into the RAM EVIC (don't have one on my truck) to see if there is an option to lengthen the interval between notifications or even turn it off. That might be worth a try, Ed.
On my SRT I can set the interval through my NAV system or turn the notification off completely. I tend to keep track of my oil change interval manually in any event.
Old 10-03-2010, 07:20 PM
Color: Mineral gray
Thanks again, Mad Dog. I'll just keep changing the oil as I have in the past (usually before the notification on the EVIC) and if the notification comes on soon thereafter I'll just reset it as I normally do and not worry if the ECM has actually been reset.
