Need help-need access to rear of radio - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-04-2010, 02:44 PM
SFD998's Avatar
SFD998 SFD998 is offline
Vehicle: 2010 Ram 1500
Trim Level: Sport Crew Cab 4X4
SFD998 is on a distinguished road
Default Need help-need access to rear of radio
Has anyone installed an aftermarket radio in a 2010 1500 with a center console? I know on my '04 there was a single scew that kept you from removing everything, but I don't see anything like that. I am not changing out the radio, but I do need to gain access to the back of it. Specifically, where the antenna connects.
Thanks for any help.
Old 10-04-2010, 02:46 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Try this. http://www.ramforumz.com/showthread.php?t=62788
Brian:
Old 10-04-2010, 02:58 PM
moparornocar72's Avatar
Rep:630
hell yeah, if it helped one person it did its job! thanks for the referral rootbeer! reps for that!
14.268 @ 95 MPH Full Trim
Old 10-04-2010, 03:00 PM
Rep:630
whatcha planning on doing?
Old 10-04-2010, 03:25 PM
SFD998's Avatar
Although, I expect some negative remarks for this I'll go ahead and tell you anyway. I installed a scanner and didn't want to run an external antenna if I didn't have to. I have already modified a bracket if I need to, but I was really trying to keep the outside of the truck clean. I purchased an antenna splitter and although I have been told they suck I wanted to give it a shot.
I installed the scanner itself under the drivers seat and ran all the wiring under the carpet and along the frame rail. I really wanted to prevent people from knowing I had a scanner installed and a splitter would accomplish this.
Old 10-04-2010, 03:29 PM
SFD998's Avatar
Originally Posted by RootBeer View Post
Thanks for the link. What a PITA though. My '04 you removed one screw took off 3 control knobs and popped the console off. Man I miss that.
Rep:630
no big deal, just post some pics! especially if you have anything to do with the law, fire or ems. Its nice being in the know sometimes!
Old 10-04-2010, 10:11 PM
chrisisbored24 chrisisbored24 is offline
chrisisbored24 is on a distinguished road
those diagrams make it look harder than it is. its 2 screws located under the little rubber cover at the bottom of the small like coin tray on the top of the center console. that tray comes out with the 2 screws then firm but gentle pressure pulling from the top of the console should just pop out.
this is how it is in my truck, column shifter no center console.
Old 10-07-2010, 02:10 PM
SFD998's Avatar
Here are some pics of the project.
The center console before:
During:
After:
Old 10-07-2010, 02:13 PM
SFD998's Avatar
The goal was to link the trucks antenna with the scanners. Here are some pics of the scanner mounted. It is located under the drivers seat.
