Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 10-04-2010, 09:41 PM
stainlessdreams's Avatar
stainlessdreams stainlessdreams is offline
Vehicle: 2005 heavy duty ram 4x4
Color: silver
Rep:42
stainlessdreams is on a distinguished road
Default Death Wobble wont go away!
so about a month ago after an inspection at the dealership they told me my tie rod ends needed to be replaced, on my way home i had my first experience with the death wobble, very violent. i installed new heavy duty Moog tie rods, tie rod ends, the entire assembley ($500). sure enuf no change, the death wobble continued sporaticaly. so i ordered the BD Diesel adjustable track bar($350), again no difference.*starting to get pissed* so i ordered the BD Diesel steering stabilizer kit($300) AGAIN! no faqin change.
i love my truck but im starting to get really pissed off at chrysler for not addressing this issue, i think we should start some sort of protest to force chrysler to take action on this.
in the mean time im wondering what i should buy next( since chrysler thinks anyone who buys a ram is made of money) i was thinking of energy suspension sway bar bushings and DT Profab +1/2" control arms.i need suggestions, my hubs and axle joints seem fine. im stumped and getting broke, im also working on my jeep ZJ and both these 4x4s are eating my bank account dry.
!!!GO CANUCKS GO!!!
Old 10-04-2010, 10:22 PM
0007 0007 is offline
Vehicle: 2008 ram
Color: Bright blue
0007 is on a distinguished road
So, you truck was fine till the inspection and it started to wobble right after?
That sounds like bizarre coincidence
I don't think anyone at dodge will want anything to do with it with aftermarket parts installed
Have you tried an alignment shop?
Old 10-04-2010, 10:36 PM
Color: silver
Rep:42
i have never even heard of the death wobble until about 5 minutes after the inspection i experienced it and did a little searching around (theres a video on youtube with the ram death wobble (exactly what my symptoms are) right after the inspection (maybe because they were pushing and prying on parts to see if there was any play in the parts) it happened to me for the first time on my way home, since then its happened 6 times and now im scared to go over 70 km/h, since it started i did install a leveling kit because i really wanted it(but the truck had the death wobble before the leveling kit was installed and was totally stock)
i dont really care if chrysler doesnt want anything to do with my truck because honestly if they know about this problem and have no intention to deal with the problem i dont want to have anything to do with them, i refuse to put any more chrysler parts on my truck unless i absolutley have no better options available. there parts are weak and there bushings are cheap rubber, the control arms look like there made from 16g sheet metal. aftermarket bushings are polyurethane and most aftermarket parts are much stronger than oem chrysler junk thats made to wear fast.
i have choosen to take my truck to sportman 4x4 shop from now on (they do all the work on my jeep zj and do awsome work) and they dont have any problem installing whatever aftermarket parts i want installed.
...oh yeah and i have performed an alignment on my truck after every install
!!!GO CANUCKS GO!!!
Old 10-04-2010, 10:56 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
I noticed your truck information shows Heavy Duty Ram. Is this a 2500? If so, I am surprised to hear of your problem. I have owned a few HD trucks, and they are usually not prone to this. Just a long shot, but is it possible that during the inspection a wheel weight was dislodged? I know from experience that this can emulate similar symptoms to the 'Death Wobble'.
brad
Interested in one of my mods?
Old 10-04-2010, 11:19 PM
Color: silver
Rep:42
yep 2005 2500 heavyduty 4x4 slt quadcab reg box, ive been reading about it on other spots on the internet and it seems to happen to lots of heavy duty rams.
ive been reading that 92 or 94-02 are quite prone to it, and the 2003-08 are getting it too, theres no doubt in my mind that the new rams will get it, the parts just havent worn enough yet, give it a few more years and youll be hearin about it the the 09s and 10s
!!!GO CANUCKS GO!!!
Old 10-04-2010, 11:27 PM
Well I can't say it's a Chrysler issue if the problem has just started since your inspection . My truck was fine , never had a 'Death Wobble" issue at all , until I installed the leveling kit . If it persists remove the leveling kit and see what it does then . You'll need to have your front end realigned though .
Old 10-04-2010, 11:41 PM
brad12kx's Avatar
Rep:2581
Long shot #2 - I had a persistent front end shake issue on Ford 1 Ton van, and after 2 years of replacing 'All the parts'.....twice, I finally instructed the front end alignment tech to add an additional 1 degree negative caster and an additional 1 degree of positive camber and set the toe in to the maximum 'in spec' value and to balance the tries as though it was a race car. I was told that it would make no difference to the issue, but the alignment error would affect the driveablity and longevity of the tires and likely cause early failure of the front end parts. After much insistence, he agreed, but I would not able to collect any warranty on the alignment.
End result - Shake gone.....no noticeable change in driveability, tires lasted 5000 miles longer than they were rated to, and for the first time....no cupping! And the front end showed no appreciable wear after 35K miles. After doing it all wrong, I was much happier with it.
Sold the van last year. The new owner had it in for a front end alignment. The 'corrected' the alignment, and he now has a front end shake problem.
brad
Old 10-04-2010, 11:46 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2823
i read that in 1 in about every hundred 4X4s that put on the Ready Lift kit, the wobble can't be corrected
to bad that there isn't some way to check for shake before you even start modifying, when i put my back wheels on the front & drive 300 miles on a short trip, my forearms get tired
Old 10-04-2010, 11:52 PM
Color: silver
Rep:42
that is something i have been reading about, setting the castors properly, but i havent found anything good enough to go on to attemp it yet. something about moving my castors all the way forward, has anyone tryed this?
im not removing my leveling kit because i had the death wobble before the leveling kit, and i like my new leveling kit, truck looks (a littlte bit) badass now, not like 8" lift badass but more badass than the horrible rake on a stock dodge.
besides that we should all be able to lift or level a truck without it crapping out on us, IMO.
!!!GO CANUCKS GO!!!
Old 10-05-2010, 12:59 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
I had a 2002 2500 that never had a problem, but i heard about many that did. Starting in 2003 the suspension completely changed up front....can't believe the problem still exists. The common fix for pre 2002 was something called Darrens steering stabilizer. It had something to do with the steering box flexing the frame. I hope you get it figured out.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
