Old 10-05-2010, 06:43 PM
RamTech RamTech is online now
Rep:1885
The solenoid pack is attached to the valve body.
Old 10-05-2010, 06:48 PM
Mtx's Avatar
Mtx Mtx is offline
Vehicle: 97 Dodge 2500
Trim Level: 2500 4x4
Color: hunter green
Rep:16
Mtx is on a distinguished road
well im trying to locate it with no such luck. both my manuals have nothing about it. checking a few other resources.
Old 10-05-2010, 07:14 PM
stainlessdreams's Avatar
stainlessdreams stainlessdreams is offline
Vehicle: 2005 heavy duty ram 4x4
Color: silver
Rep:42
stainlessdreams is on a distinguished road
this happened to me for a while in my 05, its not doing it anymore im not sure what it was but i hope you figure it out and let us know
!!!GO CANUCKS GO!!!
Old 10-05-2010, 10:08 PM
Mtx's Avatar
Mtx Mtx is offline
Color: hunter green
Rep:16
yeah. ill get up under it tomorrow and see if i can locate it if its external or not. hope so really dont have the time space or cash to drop the trans.
i cant find anything anywhere. even to buy one!
Old 10-06-2010, 05:00 PM
Mtx's Avatar
Mtx Mtx is offline
Color: hunter green
Rep:16
forgot to mention if you slam on the gas right when it shifts into the gear u want it then it will stay running until you go to stop or when it should idle then it will try and die. just cranked it up to move the truck out of the garage and it had no problems. wtfff
Old 10-07-2010, 10:47 PM
Mtx's Avatar
Mtx Mtx is offline
Color: hunter green
Rep:16
update. after sitting for a bit it will run and shift fine thru the gears until after a few mins then will stall. no codes at all. any insight?
Old 12-18-2010, 03:17 PM
M109R M109R is offline
Vehicle: 2006 Ram 1500 Big Horn----
Color: Pearl White
Rep:28
M109R is on a distinguished road
I'm with RamTech. I would lay my $$$$ on the Torque Converter giving you the issues. I'm facing the exact same issue with my '06 with the hemi. Really pisses me off to spend that kind of money on a newer truck with hopes of a realiable vehicle just to have more issues than my ex-sheriff car with 400K on it. This is what I found to buy a "new" converter for most vehicles: TorqueConverter1.com I found one for my truck for $150...refurbished, but it'll get me by for now until I get a TCI Stage II but it's $410+
2006 White QC Big Horn- Hemi
2000 Maroon Ext. cab- 360
Old 12-19-2010, 03:31 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
I would try another IAC.
Basically what the IAC does is when its at idle and when there's a load. The PCM adjusts the IAC valve (the pintle) to allow air to prevent it from stalling or idling too low. Its a stepper motor and it either moves the pintle in or out.
Try it out. Based on my experience, a bad sensor will not always throw the CEL. And its easy to access. IAC is located on the back of the TB. If it doesn't work, i'm with RamTech.
Old 09-08-2011, 02:16 AM
BuiltRamTough BuiltRamTough is offline
Vehicle: 1998 Dodge Ram 2500
BuiltRamTough is on a distinguished road
Default Help me!
I know this is an older thread, but it was never reported what the final diagnosis was. I am having the EXACT same problems right now with my '98 2500. If you could, can you please let me know what you came up with, as this thing is starting to force me to pull my hair out. As soon as the truck warms up, it starts to backfire and pop like its only running on 4 cylinders, until it finally stalls out. Idles just fine, and only does it as soon as I put the truck in gear. Thanks for help in advance.
