Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 10-05-2010, 06:52 PM
918monalisa 918monalisa is offline
918monalisa is on a distinguished road
Default 1996 dodge ram right rear brake drum
i took my tire off and my entire brake drum had brake fluid that leaked all over it, doo i need to replace the whole drum or what?
Old 10-05-2010, 06:56 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
You obviously need to change the wheel cylinder and brake shoes. As for the drum, if its still good you may be able to have it turned. However if it were mine I would simply replace the drum as well since their pretty cheap. (I'm assuming that the brake fluid got there from a leak in the line or a bad wheel cylinder)
sales@revelperformance.com
Old 10-05-2010, 07:11 PM
^^I agree^^ You can have it turned or replace it
Old 10-05-2010, 07:57 PM
Resident Technician
Rep:1909
Might want to check the axle seal while you're at it.
Old 10-05-2010, 08:03 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Used to be wheel cylinders could be rebuilt with a kit, but it does need to have the inside honed with an adapter that will go on a drill.
Drum definitely needs to be turned if putting new shoes on.
BTW, if you're working on one side, you should do new brakes on both sides.
Brian:
Old 10-05-2010, 08:27 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^^ Good Point ^^^^ Should do both sides, it's good practise (Murphys Law) If you don't the other side will follow shortly.
