5.9l gas won't rev - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-05-2010, 11:42 PM
wremote's Avatar
wremote wremote is offline
Vehicle: 1972 Dodge Dart Swinger
Color: Machetti Lime Green Metallic
wremote is on a distinguished road
Default 5.9l gas won't rev
I have a 5.9l gas that won't rev above 1000rpm. It idles at about 500 rpm and once the rpm reaches 1000 it starts to sputter and miss. This is a 5.9l with a 95 ecm. Automatic. The only code it is thowing is an AC code. There is no AC. The fuel pressure is good (45 psi)
Any help would be appreciated.
Not numbers matching but 97% MOPAR
Old 10-06-2010, 02:11 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
I don't have the answer, but more thinking out loud. It is my understanding that the ECM is capable of limiting the engine RPM when it neutral, and this value can be programmed to any value....so.....if this ECM equipped engine has been swapped into a 72 Dart, is it possible there is no connection to let the ECM know when it's in gear ? If it has been in the car for awhile running OK, and this developed recently, is there a neutral switch issue...wiring....was it bypassed and the wiring for the bypass failed ??
LOL....you came looking for answers, and you got questions!
brad
Interested in one of my mods?
Old 10-06-2010, 10:47 AM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
Have you checked your fuel pressure>?
Old 10-06-2010, 05:35 PM
Mtx's Avatar
Mtx Mtx is offline
Vehicle: 97 Dodge 2500
Trim Level: 2500 4x4
Color: hunter green
Rep:16
Mtx is on a distinguished road
says he did^
Old 10-06-2010, 06:03 PM
wremote's Avatar
The fuel pressure is good @ 45 psi. The neutral switch is hooked up.
I am using a custom wiring harness/fuse relay/terminal system from the Detail Zone (Ron Francis Wiring) and have spent considerable time debugging and verifying the system with the manufacturer.
A little more info, if I disconnect the IAC nothing happens I have checked voltages and resistance per the manual. I have checked the TPS and every thing checks out.
R
Old 10-06-2010, 06:29 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Given its a newer model motor in an older car, I'm going to ignore the age of the car.
1. Is the TB clean?
2. Is the TPS clean?
3. Vacuum leaks?
4. While fuel pressure is good as you said, does it stay that way regardless of throttle position? ie does it drop off?
Brian:
Old 10-06-2010, 08:37 PM
Resident Technician
Rep:1915
I'm liking the MAP sensor or crank sensor for a problem like this.
Old 10-07-2010, 02:42 PM
wremote's Avatar
Fuel pressure stays constant, will bump it to 50 psi though. Will thoroughly clean the TB. I will also do some testing of the MAP sensor. There is a code I do get though it has to do with the torque converter lockup. I don't have a locking torque converter as the tranny is from a 92 Dakota.
Ralph
Old 10-08-2010, 09:23 AM
wremote's Avatar
Fuel pressure remains constant, I bumped it to 50 psi also. Quick check of the MAP sensor indicated it is OK. (pulled connector and the engine stalled.)
I have only mention it is in a Dart to indicate this is a non standard instal. The best people to talk to about my engine problems are DODGE RAM guys!!
Thanx every one for all you help so far.
Ralph
"Not numbers matching but 97% MOPAR !!!"
Old 10-08-2010, 10:15 AM
Resident Technician
Rep:1915
Unplugging the MAP really isn't the best way to check one. You really need a lab scope and a vacuum gauge or you can try replacing it with a known good part (not necessarily a new one).
