Braided Stainless Steel Brake Lines Question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 10-06-2010, 10:01 AM
WesGPS's Avatar
WesGPS WesGPS is offline
Vehicle: 2005 Dodge Ram HD 4x4 S. Box
Rep:68
WesGPS will become famous soon enough
Question Braided Stainless Steel Brake Lines Question
I posed a question in another thread about how to improve my brakes. I received an excellent answer from RamTech Randy, to which I responded:
"I'm down with all your recommendations including the braided lines, if for no other reason than they look trick - so I will no doubt be putting them on along with your other recommendations.
This question: When all is said and done what do the braided lines get me performance wise? "
I'm sure he has a perfectly valid technical reason, it's just that, "Inquiring minds want to know" - Can someone enlighten me on the performance issue a bit?
Thanks in advance. Wes
WesGPS.com
2005 Dodge Quad Cab Heavy Duty 4X4 5.7L Hemi.
Air Lift Remotely Controlled Air Bags.
Hellwig Rear Anti Sway Bar.
Viair Onboard Air System.
Old 10-06-2010, 12:46 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Performance wise very little. They are flexible but that's about it.
Brian:
Old 10-18-2010, 11:41 PM
NuclearRam's Avatar
NuclearRam NuclearRam is offline
Vehicle: 2001 Ram 1500
Trim Level: Laramie SLT Quad Cab
Rep:20
NuclearRam is on a distinguished road
Yeah, if anything, they're just a higher quality of make than OEM, but it won't do much performance wise.
Old 10-20-2010, 02:59 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Back in the day the major difference (so I've been told) between SS braided lines and rubber lines was that the rubber lines would tend to expand (think long skinny balloon) under high pressure. The braided lines act more like a flexible pipe allowing the pressure to be transferred more directly through the brake fluid rather than expanding the lines. It led to more responsive/efficient braking. With today's better materials and computer controlled ABS systems, I doubt you see that much of a performance gain though. Much more of a cosmetic gain IMHO.
Old 10-20-2010, 05:19 PM
I'll say they make a major difference and it ain't about looks.
Consider this:
the stock rubber lines will weaken over time, expanding with pressure of repeated braking, and leading to braking efficiency loss and a soft, weaker pedal feel.
the braided steel line will not expand over time with repeated braking, maintaining braking efficiency and pedal firmness.
of course, this is a bit esoteric and has more of a race application but I always change my brake lines out to braided steel lines pretty early in the ownership cycle. And I've never had to replace them after installation except once I damaged one (and I could only get a set for the rear) while racing my 350Z.
I have braided lines on the RAM and the SRT currently. I also tend to replace the brake fluid with a step up in DOT ratings.
Brake fluids are classified by both “dry boiling point” and “wet boiling point”. They are also classified by US Department of Transportation (DOT) rating, DOT 3, DOT 4, DOT 5, and DOT 5.1.
As we would expect the dry boiling point is just that - the temperature at which a given brake fluid boil when it is fresh out of the can. This is the rating by which most high performance drivers and all racers select their brake fluid – from the standard racing 550 degrees Fahrenheit to the 600+ degrees Fahrenheit offered by the extreme use fluids. As a point of interest, even though they may have the same DOT rating, racing fluids are less compressible than street fluids, especially after they have been overheated.
For high performance street car use, the wet boiling point is at least as important as the dry. DOT 3 DOT 4, and DOT 5.1 brake fluids are ether based and, as such they are hygroscopic in nature - i.e. they adsorb water at every opportunity. Since water boils at 212 degrees Fahrenheit (100 degrees Celsius) the adsorbed water dramatically lowers the boiling point of the brake fluid. A minute amount of water suspended in the fluid decreases the boiling point as much as 1/3. Damn!
The fluid in the system absorbs water through the breathers, through the caliper piston seals and by magic. Not only does this reduce the boiling point, the entrained water leads to corrosion of both ferrous and Aluminum internal parts. Double Damn!! So buy your brake fluid in small containers and don’t save the leftovers.
Old 10-20-2010, 05:43 PM
Resident Technician
Rep:1915
Maddog has pretty much summed it up. Braided steel lines will give you improved performance as well as firmer feeling brake pedal.
Old 10-20-2010, 06:07 PM
Color: RootBeer
Rep:1287
Great post Michael.
Brian:
Old 10-20-2010, 06:20 PM
Resident Technician
Rep:1915
One thing you don't want to do is use DOT 5 or 5.1 in a system that requires DOT 3 or 4.
Old 10-21-2010, 08:13 AM
I totally agree with Randy on that ^^^^. Most passenger vehicles are rated at DOT 3 and a step up to DOT 4 is all you really need, especially if you tow a lot.
Old 10-21-2010, 08:47 AM
Resident Technician
Rep:1915
That and the fact that DOT 5 fluids are silocone based and will NOT intermix and could cause damage to the brake system seals.
