Old 12-31-2011, 12:02 PM
chuckie chuckie is offline
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
chuckie will become famous soon enoughchuckie will become famous soon enough
Looking good jmr, I didn't realize 4" hose would fit, may have to change mine.
Old 01-02-2012, 10:05 AM
milkbone789's Avatar
milkbone789 milkbone789 is offline
Vehicle: 2005 Dodge Ram Quad Cab Hemi
Color: Bright Silver Metalic
milkbone789 is on a distinguished road
Originally Posted by Hedghawg71 View Post
Pretty clean! I want to do that but all the way across and I have yet to find anyone who carries the mesh with that pattern in 6 foot widths. Hell if Home Depot or Lowes had it (and yes I know that will rust if it isn't treated) I would buy it, cut it to fit and get it powder coated satin black.
Hedgehawg,
Next time youre at Lowe's, check out metal lathing use in plaster and stucco applications. It should come in the width you require and is rust resistant due to the caustic nature of stucco.....just a thought.
Also, when handling this stuff, be sure to use leather gloves. It will leave nasty scars....
Life is too fast to drive slow....
Old 01-02-2012, 11:21 AM
Hedghawg71's Avatar
Hedghawg71 Hedghawg71 is offline
Vehicle: 2011 Dodge Ram Express
Rep:21
Hedghawg71 is on a distinguished road
Originally Posted by milkbone789 View Post
Hedgehawg,
I'll check that out today or tomorrow, and thanks for the heads up.
Nothing a Hammer can't fix!
Old 01-02-2012, 12:40 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
I went to Lowe's lumber dept and bought a 3' peice of plastic gutter guard.
The material is easy to work with and with Permatex Black RTV + Duct Tape
it really bonds them to the lower grille.
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
Old 01-05-2012, 01:29 AM
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
This is truly a cold air intake. I have an aeroforce interceptor gauge in my truck and air intake temperature readings from the sensor in the intake tube are one of the many parameters it can monitor. I am pleased to report that this mod really does work. Before I installed the 3" hose to my stock airbox I was running around 15-20 degrees air intake temps above ambient ( the ambient is the outside temp reading on our dash) In other words if the outside temp was 70 the intake tube temp would vary
from 85-90 degrees. Now with the hose installed it is running 8-10 degrees above ambient ! Of course sitting at a traffic light the temp goes up since not much air is moving, but once you start rolling the temp drops fast. My gauge also can do 0-60 and 1/4 mile times. I will post this as soon as I get some data
Old 01-05-2012, 09:18 AM
mrboots's Avatar
mrboots mrboots is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Big Horn Edition
Color: Inferno Red
Rep:137
mrboots will become famous soon enoughmrboots will become famous soon enough
I did something similar to this with my 2008, except at the bottom of the tube I attached a register, found it at the ductwork section at Lowe's. Not sure, but it LOOKS like it would be able to scoop more air into the tube. I ripped out that stupid, hideous black plastic insert in my bumper, and then covered it with some expanded steel.
I pulled out the black part above and between the fog lights...
Here's the register. It's essentially a 'scoop' that has an outlet to attach the tube to on the other side, so it gives a lot more surface area than just having a tube end.
I ran it without anything in place for a while, but thought it looked kinda unfinished, so I cut some expanded steel up and placed it there. Looks so much better and it doesn't really block any airflow. Here's a test fit.
And the finished product:
2008 Dodge Ram
35% Tint, Flowmaster 40, Custom painted interior, Painted grill emblem, Custom CAI,6000k HID Fogs/6000k Grill lights, Custom bed LED's, Blue dash LED's, Engine bay/interior lighting, Custom audio, 4" Raptor Nerf Bars, Cooper Zeon LTZ's, Diablosport 93 oct. tune
Old 01-05-2012, 10:11 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Guys great MOD, one question I took a quick glance at my lower grill and wonder how easy is it to get out?
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 01-05-2012, 01:42 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Great info chuckie..
Mr boots, I thought youhad hid headlights too?
-Pat-
Old 01-05-2012, 02:34 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Ihave a question do you think this would improve my set up as far as getting more air to it or leave mine alone .
Old 01-05-2012, 02:54 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
dodgert: It would help. Your intake still grabs air from the fender which is a small inlet.
Sean
