tonneaucovered.com
Old 01-05-2012, 03:11 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Yea Dodge it won't hurt anything but that pretty box LOL
Also I wonder if you did this to a volant if it would be a greater difference than stock or even a stock volant
-Pat-
Old 01-05-2012, 04:24 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
DodgeRT,
I would drill a 4" hole in the bottom of that heat shield below the filter then put a 4" alum tubing like we've done. Then open up the lower grille and have the tubing sit behind it.
Chuckie has proven that this mod works by getting the reading from the IAT sensor and noticing it's just a few degrees hotter than the ambient temp. I veried that air is definately being rammed into the airbox. I used my portable wind tunnel (leaf blower) and aiming it towards the bumper from 3 feet away.
Next the airbox lid was removed along with the filter then the blower was tuerned on and sure enough a nice strong stream of air flowed into the 4" tubing. So it's working allright.
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
Old 01-05-2012, 04:30 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Originally Posted by jmr View Post
DodgeRT,
I think i will do this hows the hole saw work on metal and got part names of the stuff from lowes -home depot and what i was thinking was poping the bottom grill off getting some kind of mesh paint it black then make a scoop to hook the tube to by the grill
Old 01-05-2012, 10:37 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
The Volant comes w/ a 4" flange already molded into the bottom of the box. It's for their ram air attachment that they have yet to design/release for the '09-'12's. I've got a section of 4" dryer vent hooked up to mine and routed to the bottom of the engine bay behind the bumper and like it a lot.
I'm also planning on adding a flapper to my stock fender inlet to 'encourage' the intake to take from the lower dryer vent tube rather than the restricted fender inlet. If the engine needs more air during WOT the pressure differential across the flapper should force it open and provide the added air. We'll see.
Old 01-06-2012, 03:04 PM
BlackHemI's Avatar
Rep:296
Yea but their attatchment is expensive so I'd stick with the mod everyone's doing to save $$
-Pat-
Old 01-09-2012, 02:22 PM
mrboots's Avatar
mrboots mrboots is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Big Horn Edition
Color: Inferno Red
Rep:137
mrboots will become famous soon enoughmrboots will become famous soon enough
Great info chuckie..
Mr boots, I thought youhad hid headlights too?
Nope, not yet. Just the fogs and the grill lights right now. Still debating on what company I want to use for the headlights mostly.
2008 Dodge Ram
35% Tint, Flowmaster 10, Custom painted interior, Custom CAI,6000k HID Fogs/6000k Grill lights, Custom bed LED's, Blue dash LED's, Engine bay/interior lighting, Custom audio, 4" Raptor Nerf Bars, Cooper Zeon LTZ's, Diablosport 93 oct. tune
Old 01-09-2012, 02:41 PM
BlackHemI's Avatar
Rep:296
I took my hids out of.my.fogs this.weekend.because.one of.my bulbs was out. If I come across a deal ill buy a new set
-Pat-
Old 01-16-2012, 01:23 AM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
Wow, I came across this thread after looking for something to use to do this with the spectre CAI I just ordered. I'm out of the U.S. now, so I can't just go to a lowes and look around. This is what I ordered, and it looks to be perfect. I found it on amazon, and it's called Amerimax FlexDNSPTExtension
They have black as well, but wanted 20 dollars to ship it, and the green one had free shipping, so I will just spray it with plasti dip.
It can be stretched out to up to just under 5 feet
I also ordered some polyester mesh material with a few different micron openings, thinking of it as a moisture filter. I was going to experiment with a few different micron sizes to see if it restricts the air flow too much. http://www.amazon.com/gp/product/B00...02_i00_details
Old 01-16-2012, 01:50 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Yep, saw that stuff at Lowe's when I was getting the stuff for mine. I went with RV sewer line, but they have all kinds of downspout PVC parts, drain hose, and fittings to work with there. I do not think you have to worry about water entry if you're mounting the opening down lower. With the other OEM opening in the fender well, you will not get any draw from the engine strong enough to pull water up that intake hose. It's like having a big hole in your soda straw and trying to suck cola through it...ain't happening. If that lower intake opening was your only opening then you'd have something to worry about in an extreme case. You still get plenty of air volume, just not a vacuum that will draw water into the airbox.
Old 01-16-2012, 02:12 AM
Color: Flat Black
Yeah, I realize it wouldn't create the straw effect, if it were submerged, the air would just be drawn from the other air supply. I'm just not sure how much water it would take to do any damage. I can see water droplets being sucked up in a rain storm, would that be a hazard to be concerned with?
