Old 01-16-2012, 08:57 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I can see water droplets being sucked up in a rain storm, would that be a hazard to be concerned with?
No concern. Small droplets of water will be stopped by the filter. In all honesty, and engine can take in small amounts of water and it won't do any harm, it can actually be a good thing, lowering combustion temperatures and can help clean the combustion chamber. It's when you get a lot of water that it's a problem.
Sean
Old 01-16-2012, 11:27 AM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
good to know, thanks
Old 01-16-2012, 11:42 AM
snrusnak's Avatar
Rep:1385
No problem. I have met guys at the race track that actually run "water injection" in small doses through nitrous taps. They gain power by having a cooler combustion. Pretty neat idea, and water is basically free...
Sean
Old 01-16-2012, 11:54 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
There would be no more water and probably less having the ability to get inside the airbox with the lower mounted hose mod compared to the OEM fender inlet. The headlight is in front of the space for that fender OEM air inlet. The headlight is not sealed at the perimeter of the housing. Driving at 70 mph in the rain is like a high pressure car wash at the perimeter, and some water gets sprayed around in the fender area where the OEM inlet is drawing air. Even with the inlet fairly level to the headlight, there's not a problem with water being drawn into the airbox, even with just the one OEM opening. The added hose inlet mod with a lower intake probably has less ability to draw water. Unless you mount the lower intake opening in a ram air attempt with the opening facing out the front of the bumper fascia, water will have an extremely hard time making any headway up that hose. Even with a ram air setup, you have gravity and distance working against water intake. Add to that the OEM inlet which prevents a stronger vacuum, and you're just not going to have an issue.
I would suggest this. Mount the modded hose inlet the way you want it. Wait for a good rain and maybe even drive through a couple of decent water puddles/crossings. Don't go crazy by driving through a river crossing...LOL! Now, you know how easy it is to pop open the airbox lid. Inspect the bottom of the box and two inlets for any appreciable evidence of water. I think you might find you're looking for a solution to a non-existent problem.
Old 01-16-2012, 10:27 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
The engineers must have thought that water would get into the airbox too because there is a 1/4" water drain hole in the bottom of the airbox.
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
Old 02-16-2012, 03:34 PM
dodgeram02's Avatar
dodgeram02 dodgeram02 is offline
Vehicle: 2011 Dodge Ram 1500 Quad Cab
Rep:59
dodgeram02 will become famous soon enough
hey autobred, what size pipe did you use on the stock air tube? i have been wanting to do this since i got my new ram, but i dont know what size pipe i need and if it needs to have any bend to it? and was there anything else you needed to do this?
"I dont lie to my wife about my truck...I dont lie to my truck about my wife, they both know, no matter how good they treat me I'm still going to get on the other one"
Old 02-18-2012, 01:52 AM
hemi07's Avatar
hemi07 hemi07 is offline
Vehicle: 2010 ram
Color: blue
Rep:12
hemi07 is on a distinguished road
What kind of air filter did u guys use
Old 02-18-2012, 02:02 AM
Dodge891's Avatar
Dodge891 Dodge891 is offline
Vehicle: 2001 dodge ram
Trim Level: Single cab short bed
Color: Vader Black
Rep:48
Dodge891 is on a distinguished road
looks good bruh great idea
Sparky says RAM IT
Old 02-18-2012, 03:20 PM
TNC TNC is offline
Rep:12
K&N stock replacement size for the stock airbox. On that note, It would be interesting to see how many square inches of actual filter surface are actually contained in some of the aftermarket CAI units. I'm not saying they don't have more area, but it would just be neat for comparison's sake.
Old 02-19-2012, 07:48 PM
crash6873 crash6873 is offline
Vehicle: 2003 ram 1500
crash6873 is on a distinguished road
Hey guys,
I have been reading through this post and it seems that you all have newer trucks than mine. I have an 03 and mine is a standard trim truck (no driving lights). Has anyone ever tried to do a "ram air" by removing the round plastic plugs that fill the places where the driving lights usually mount? I haven't looked up under there yet, but just curious if anyone has tried it or if there is some reason it cannot be done.
