Airbox Intake Tube Mod - Page 15 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 03-13-2012, 08:17 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2016 RAM 1500 Express QC 4WD
Trim Level: Express Quad Cab
Rep:86
jmr will become famous soon enough
If it's 4" tube don't use a flange just feed the pipe into the bottom of the airbox. The aluminum tube can easily be formed so it's possible to make a compact short radius elbow from it.
I've done this for other cars my Caliber where this isn't much room under the hood.
'16 RAM 1500 Express QC 4WD 5.7L, 8SPD, 3.21 W/LSD Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner/Mud Guards/Skid Plates, Lund Tri-Fold Cover, Black RAM Emblems, Homelink Overhead Console
Old 03-13-2012, 09:59 PM
hwy97 hwy97 is offline
Vehicle: 2007 Quad Cab 4x4
Color: Bright Blue
hwy97 is on a distinguished road
Thanks guys, I'll tackle it again this weekend. This is my 3rd, 3rd gen Dodge PU. My '04 and '06 were diesels. I wasn't pulling trailers any longer so I bought the Hemi. I've left it rock stock until a couple weeks ago starting with a Diablo Sport tuner and this minor mod. to the air box with a K & N. Some kind of Mangnaflow system next.
Old 03-13-2012, 11:12 PM
mikeski's Avatar
mikeski mikeski is offline
Vehicle: 2012 Ram Quad Cab 1500
Color: True Blue Pearl
Rep:25
mikeski is on a distinguished road
Send a message via AIM to mikeski
Ya, I learned to look at the users truck info. Saves some head scratching.
me...
Mikeski.....
Morimoto Mini H1 Projector's w/ Digital 55watt 6000k HID's, 35W 10k HID Fog Lights, Blue LED's throughout the interior, Bed and Reverse LED's, Oil Catch Can, 4" vent to stock air box and two beady red eyes. Where will the madness end????
Old 03-13-2012, 11:34 PM
mccritter's Avatar
mccritter mccritter is offline
Vehicle: 2015 Dodge Ram 2500
Color: Blacked Out Edition
Rep:26
mccritter is on a distinguished road
Nice information here I will be doing something like this and the pictures and info in here are great. I'm wondering if anyone has found an alternative to the drain/dryer vent that isn't ridged? I've been looking around but anything I've found is pricy so it defeats the whole purpose.
I'm in the industrial electrical industry and have access to conduit and benders and I am thinking about custom bending something. I haven't removed my airbox to look at the routing yet but does anyone have any insight as to if it would be possible to get a solid peice routed down there?
Old 03-13-2012, 11:35 PM
mccritter's Avatar
Rep:26
ohh I would be using 3" conduit if that makes a difference
Old 03-14-2012, 12:05 AM
Color: Bright Blue
But what about that 4" hole I drilled??
Old 03-14-2012, 12:07 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
I think the concern for the ribbed interior in this portion of the intake may be overrated. You're looking for more volume, and I don't think the intake flow really starts accelerating until it's reduced down at the throttle body intake tube from the airbox to the TB. Sure, there's some noticeable flow at both intake holes, but I don't think the ribs at this point are much of a hinderance, if any. There's been some discussion about the OEM ribbed throttle body tube, and this may have more credence. The flow is accelerating much more here just due to the reduction in intake diameter...like at a carb venturi. I'd want to see a flow bench test to absolutely confirm that, but it has more logic associated with it. All the aftermarket TB tubes appear to be smooth, so it's either because it's easier to make them that way...it really does improve/perserve flow...or both.
Old 03-14-2012, 12:23 AM
mikeski's Avatar
Rep:25
Has anyone tried to form a pipe? I was looking at my vent tube from day one. How can I replace that with something nicer. I don't meant to say the pipe as it is looks bad. It has a great industrial feel to it.
I would really like to build a pipe that runs all the way to the hole in the front bumper trim I will need to make. I think it can be done as one piece. Or maybe a couple more manageable sections.
Maybe fiberglass? Cast something?? Hmmmm, how would dip work?? Dip is going to take on the contour of every bump?? or will it kinda level out some imperfections? Would the 4" tube I have now show smooth or ribbed for my baby's pleasure??
Lord, I'd like to apologize for .....
me....
Mikeski.....
Old 03-14-2012, 08:43 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
It is true that ribbed tube vs smooth tube actually makes very little(almost negligable, actually) difference on an intake. I've seen both flow testing and dyno comparisons.
Sean
Old 03-14-2012, 09:22 AM
mrboots's Avatar
mrboots mrboots is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Big Horn Edition
Color: Inferno Red
Rep:137
mrboots will become famous soon enoughmrboots will become famous soon enough
Originally Posted by hwy97 View Post
Now I see most of these have been done to 4th gen's. I punched a 4" in the bottom of my '07's air box, it looked like it would clear no problem. It's a problem...I ended up just having a very short straight intake because of the short distance between the bottom of the air box to the top of the plastic inner fender. I not going to cut up the inner fender and even past that issue it's tight between the inner fender above the upper control area to get an intake tube to a better air supply. I had found a cool piece of plastic gutter drain that went from 4" round to a flat 2" x 6" flat that would have fit perfect between the space in front of the upper control arm but the 4" round wouldn't fit between the bottom of the air box and the inner fender. In the pic's it looks like not only is there more room under the air box, but more room to run a intake hose
Well damn, I could have swore that I posted in this thread a while back. Anyways, here's an excerpt from my small build thread, I did this last year, I really think it helps collect air into the tube, and it looks much better to me personally.
"Finally, I was in the hardware store a few weeks ago and ran across some expanded steel, so I got an idea. A couple months ago I removed the plastic trim piece in my bumper and added an aluminum register with three inch flex pipe than ran up to my air filter. I did this to get some more cool air forced up into my air filter obviously. I've seen a few guys do this, but instead of just leaving the end of the tube down there, I figured if I added the register I would probably be able to collect a little more air. If you don't know, a register is a piece of aluminum in a rectangle that transitions into an outlet for a tube. I'm rambling. Long story short, I didn't like the big opening left in my bumper. At first I thought it looked 'tough', but kinda got over it. So, I needed something to cover this somewhat, but still allow air to flow through. So the expanded steel was perfect. Lowe's didn't have anything longer than 24 inches, and my opening was 48 inches wide. I cut it in half, used metal zip ties to secure it to the top, which you can't even see, and then some sticky butyl-type matting I had. It wasn't very hard, it was cheap, and I love the end result. So with with that being said, here come the pictures..
Here you can see the black part in the bumper between the two fog lights, this is what I pulled out and where I ran the tube from my airbox down to:
The opening in my bumper after I pulled out the black plastic part:
In this one you can see the register(I painted it black):
ACTION SHOT!:
End result:
2008 Dodge Ram
35% Tint, Flowmaster 10, Custom painted interior, Custom CAI,6000k HID Fogs/6000k Grill lights, Custom bed LED's, Blue dash LED's, Engine bay/interior lighting, Custom audio, 4" Raptor Nerf Bars, Cooper Zeon LTZ's, Diablosport 93 oct. tune
