Airbox Intake Tube Mod - Page 20 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 05-06-2013, 11:48 PM
kittpowell1's Avatar
kittpowell1 kittpowell1 is offline
Vehicle: 2004 ram 1500
Color: red
Rep:17
kittpowell1 is on a distinguished road
Default any suggestions on modifying my open lid k&n cia
I want to try and set up my k&n cia with your design i was thinking of cutting a hole in the bottom of my box running flex tube down to where my fog lamps are removing them and having the tubes mounted in the lamp openings what are your guys thoughts? I know it wont give me nearly the same results if i bought a true ram air system but is there any gains in lower temps, improved mpg and hp? Or am i wasting time?
Old 05-20-2013, 02:02 PM
Color: red
Rep:17
i did this mod i used 4" pipe running into my lower bumper removed my fog lamp as soon as i started driving my ETC went off i reset my computer by removing negative side worked start driving it goes off the guy at dealership says it might be my mass air flow sensor which makes sense so my question is are any of you experiancing the same issues how do i by pass this issue?
Old 05-20-2013, 02:29 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Redneck ingenuity at it's best
got ta love it
but you can't knock it if it works
Old 05-20-2013, 05:10 PM
Color: red
Rep:17
could you explain how i can stop my mass air flow sensor from tripping off my ETC my mod is working to well
Old 05-20-2013, 06:06 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
^your truck does not have a maf sensor.
Sean
Old 05-22-2013, 07:13 AM
Iqudayo's Avatar
Rep:563
Did you disconnect the battery before you did it ? then plug it back in.
Old 06-05-2013, 01:28 PM
RAMeister's Avatar
RAMeister RAMeister is offline
Vehicle: 2011 RAM 1500 Laramie Crewcab
Color: Black/Gold
RAMeister is on a distinguished road
Arrow
Nice DYI project... Thanks for sharing it.
TTFN
Tim
Old 06-05-2013, 01:36 PM
Iqudayo's Avatar
Rep:563
Originally Posted by SoCal Ram View Post
Me too. Been reading this thread for days. From what I gather this stock intake with the DIY mod is just as good as a CAI for someone who is only going to do the "Big 3", Intake - exhaust - tuner. So I went ahead and bought a used airbox off Amazon, $58+ change shipped. The used airbox came with this intake hose/tube. Looks to be from a 4.7L or something Ram??? But it's real nice, it makes this mod look very OEM!!! Also bought the Airaid performance drop-in, dry filter ($56). Went to Home Depot looking and bought a few things. What ended up working for me were 2 x 3" PVC drain connectors (the black PVC, $20). There were/are 3 curved pieces to chose from, I used the shortest of the three at both ends of the intake tube. Used a 3.5" hole saw (I borrowed) and the PVC fit so perfect it was meant to be! The PVC did take some sanding to make the curve fit all the way down but it worked after a while. Anyway, I used the OEM intake tube on the end of the PVC coming out the air box and a second piece of PVC at the other end (Sorta like a scoop) to bring the intake tube off the metal frame (it was laying right on top and was obstructed) for better airflow. The intake tube was a very nice surprise. It has clamps on both ends. Clamped right to the box end, I had to duct tape the "Scoop" end a bit to make a tight clamp. This is it, my DIY CAI. Do I feel a difference or hear anything different, NO! Not a dam thing. At least I can feel I've done the best for my truck and with an exhaust and tuner I'll eventually reap the benefits of this DIY CAI. Thanks for the great thread, it was fun if nothing else.
Fantastic work Props To You
Old 06-05-2013, 02:21 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2016 RAM 1500 Express QC 4WD
Trim Level: Express Quad Cab
Rep:86
jmr will become famous soon enough
I can tell you that it's scooping some air in given the bugs laying in the bottom of the airbox. I'm glad people are able to use this mod, can't believe this thread is still going since my original post back in 10/07/10.
People might think the factory airbox is too restrictive but with a secondary air source it's not. Even the factory is has a secondary air inlet for the heavy duty RAMs now. I was shopping for a MIT modular Intake Tube and called AIRAID and they told me that they don't sell separately for the 4th gen RAM because the factory tube is already a good design.
'16 RAM 1500 Express QC 4WD 5.7L, 8SPD, 3.21 W/LSD Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner/Mud Guards/Skid Plates, Lund Tri-Fold Cover, Black RAM Emblems, Homelink Overhead Console
Old 06-05-2013, 11:48 PM
storeboy storeboy is offline
Vehicle: 2009 Dodge Ram
Rep:34
storeboy is on a distinguished road
I have been using this for about nine months now and it works great, especially in the spring/summer.
