Old 06-16-2013, 01:55 PM
bigbossin bigbossin is offline
Vehicle: 2012 ram 1500
Trim Level: slt big horn
Color: midnight blue
bigbossin is on a distinguished road
Pretty stocked about to do this mod tomorrow
Old 06-16-2013, 04:42 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
If you don't want to use parts from Lowe's and such, check out Spectre brand components( available at o'Reiley's auto Parts). They have everything you need to do this mod super clean and look great. I got all my parts from an older project. The next few days mine is going in, I will do pics. I aqlready have a the Green Performance drop in air filter, so hopefully this will give her all she can take.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 06-18-2013, 08:37 PM
Sweetee Sweetee is offline
Vehicle: 2012 Ram 1500 ST
Rep:22
Sweetee is on a distinguished road
Default Cooler air!
Greetings! I have followed this thread for some time and finally "bit the bullet." We don't have Lowes or Home Depot close by, but Menards had everything I needed.
I carefully marked where I could cut the 3+" hole. Not having a hole saw, I drilled 1/8" holes around the circumference and then used my Dremel tool to finish off the opening. I cut the top inch off the collar of the street elbow with my hack saw and smoothed the edges with sandpaper.
Originally I was going to epoxy the street elbow, but noticed that when using the Dremel tool that the air box material would virtually melt from the friction. Instead of using epoxy, I used an old soldering gun to melt pieces of the cutout from the air box to form a bond between the street elbow and the air box. When the airbox material was molten, I could press it into the gaps using an old kitchen knife. It was almost like frosting a cake and the street elbow is locked in place. I even checked after I was done and it is water-tight too.
I hit the street elbow with a couple coats of flat black before reinstalling the air box. The solid drain pipe is an accordion that is about 2.5' before you pull it out. I attached it to the street elbow and ran it down against the inner fender well and routed it just behind the front fascia. I know pix would be helpful, but I currently don't have any way to post.
The total, not counting the paint, was less than $10. For the past three weeks I have been comparing my IAT against the ambient temperature. At highway speeds, the IAT would be between 14 and 17 higher than air temperature. Since doing this mod, the difference between IAT and ambient air temperature runs from 5 to 9 degrees. I took it out to show my "service guy" at the dealership and he was impressed.
Thanks to all for inspiring this mod!
3" 45Deg PVC Strt Elbow
Model Number: K04415C | Menards® SKU: 6892393
4"X8' Solid drain Pipe
Model Number: 54021 | Menards® SKU: 6893771
4" Metal Worm Gear Clamp
Model Number: MC4ZW | Menards® SKU: 6399369
Old 06-19-2013, 12:29 AM
Taylo1's Avatar
Taylo1 Taylo1 is offline
Vehicle: 2012 Dodge Ram 2500 4x4
Trim Level: Outdoorsman
Rep:88
Taylo1 will become famous soon enough
I want to do this can you send pictures to me by way of email? kmtaylor66@sbcglobal.net
Thanks
Old 06-19-2013, 10:26 AM
Rep:22
Default Air Box
Here are my first attempts at attaching photos. Hope this helps.
Old 06-19-2013, 10:50 AM
Taylo1's Avatar
Rep:88
That works! thanks for posting pictures.
Old 06-27-2013, 08:55 PM
bouf0010's Avatar
bouf0010 bouf0010 is offline
Vehicle: 2013 Dodge Ram 1500
bouf0010 is on a distinguished road
I read this front to back and back to front a couple times and decided to do this mod as well, even though i have an AFE stage 2 CAI (really its warm air, but cold air now!)
I used a 4" dryer vent for the tubing, a 4" drain inside the box and a 4-5" rubber coupler for the intake portion.
T-1000 HF 93 Tuned - S&B CAI w/custom air scoop - Moe's 87mm tb - Silver Ceramic JBA Shorties - Magnaflow Y-pipe - GT Custom 22" muffler - V6 E-fan mod - 180 t-stat - Catch Can - bielstein shocks - 2" rear drop coils - Cooper Zeon LTZ 305/55R20
Old 06-27-2013, 09:05 PM
ckmb4's Avatar
ckmb4 ckmb4 is offline
Vehicle: 2013 Ram 1500 Express
Rep:17
ckmb4 is on a distinguished road
I like the way you added the screen on the lower valance. What did you use. Did u just dremel it out? I'm curious that's how I'm wanting to do mine.
Old 06-27-2013, 09:23 PM
bouf0010's Avatar
Thanks!
Yeah i used dremel, the shape for the hole was kind of already there, i just had to cut it out. As for the screen, i just went to canadian tire (hardware store with auto parts) and bought some customizing meshing.
I cut a piece out with about an extra inch all around and bent and shaped it until it fit in the hole. I bent the extra around the back, glued it with JB weld and cut the excess with the dremel once it was dry. A couple coats of plasti dip and it was good to go!
Old 06-27-2013, 09:25 PM
ckmb4's Avatar
Rep:17
That's good stuff man. Consider mine done!!
