Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Dodge Ram Decals
Old 12-11-2011, 02:41 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Yea the hole is at the bottom of the box so it still travels through the filter
-Pat-
Old 12-11-2011, 11:47 AM
TheDon's Avatar
TheDon TheDon is offline
Vehicle: 2012 6.7 cummins 2500 mega cab
Trim Level: big horn
Rep:15
TheDon is on a distinguished road
Yes you are correct, I went out and looked at the airbox again and it would travel through the fliter, my bad, I'm still getting to know Dodge rams, sorry and thanks for answering.
2012 White Dodge ram 2500 6.7 Cummins HO. BDS 8'' long arm lift, Pure Performance track bar, FOX 2.0's, 20x10 Rockstars, 37" Toyo, BD steering brace, H&S tuner 175hp, H&S cooler delete, GDP Intake horn, boost tube & CCV delete, DPF/Cat delete, S&B CAI, AMP research steps. Timbren bump stops.
Old 12-11-2011, 12:15 PM
BlackHemI's Avatar
Rep:296
no problem man, you should look into this, a great mod for 30$ is not bad and it really gets true cold air in
-Pat-
Old 12-11-2011, 12:46 PM
TheDon's Avatar
Rep:15
I definitely will, I live at home depot lol. I'm a big fan of cheap mods such as this one and I will put the airbox vents on as well (I was a former MX racer for 25 years, we always did these mods) Thanks for the tip.
Old 12-11-2011, 12:57 PM
BlackHemI's Avatar
Rep:296
sweet post pics of it when completed!
-Pat-
Old 12-16-2011, 08:38 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Again, thanks to jmr for coming up with what is definitely an inexpensive airbox mod that would seem to yield a benefit under any logical assessment.
I had already installed the K&N filter for the OEM box. I did the 3" hole saw deal but used some RV sewer parts for the hose and 3" airbox hole...3" is standard size stuff for RV sewer lines and fittings. I liked the longer snout on the airbox hose connector, so it was easier to slip on the 3" sewer hose and clamp it to the fitting. It was a tight, press-fit for the airbox fitting. I was going to seal it with some foam or silicone, but it fits way tighter than that OEM air inlet just above it. Apparently since you're on the dirty side of the filter, it's not a big deal, and I doubt much hot engine bay air is going in the airbox.
I used a 2 foot length of flexible sewer hose and installed a 3" PVC downspout connector at the end. I toyed with the idea of making a ram air setup by cutting a hole in the fake grill area, but I don't think there's much gain in this application. I ziptied the downspout connector to a convenient location over to the right side, as low as possible without having to worry about it hitting anything by running over something.
It's not much different than jmr's setup but just uses different materials.
Old 12-16-2011, 11:33 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2016 RAM 1500 Express QC 4WD
Trim Level: Express Quad Cab
Rep:77
jmr will become famous soon enough
TNC that looks like a really good installation and I'm happy to help out fellow RAM owners.
The mod works, try putting your hand over the inlet end of the 3" tubing when the engine is running and you'll feel the air going into the engine.
This tells me that the original 3.5" x 4" snorkel in the airbox from the factory isn't a big enough inlet for the engine.
You know I found some 4" flexible aluminum tubing near the 3" tubing at Lowes. So now I'm wondering if 4" would fit in the area where I drilled the 3" hole or maybe run another 3" piece of tubing to the airbox. More AIR!!!!
I've been running this setup for over 3,000 miles and have only noticed very small debris such as pieces of leaves and a couple insects on the bottom of the airbox but nothing in the filter itself. If somebody is really worried they could fit some furnace filter material or something similar into the 3" tubing to trap the debris.
'16 RAM 1500 Express QC 4WD 5.7L, 8SPD, 3.21 W/LSD Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner/Mud Guards/Skid Plates, Lund Tri-Fold Cover, Black RAM Emblems, Homelink Overhead Console
Old 12-17-2011, 12:24 AM
TNC TNC is offline
Rep:12
LOL!...yeah, I've thought about the dual 3" inlet deal too. I even looked at a 4" PVC downspout fitting that would work at the airbox by making the airbox hole rectangular and then use 4" hose all the way. But you know what?...I think this current 3" hole probably adds all the engine needs with the OEM sized high flow filter and the OEM inlet. With the airbox and borla muffler exhaust mod, I think this truck has to be hitting at least 400 hp. Frankly that's enough for me at this point. The exhaust and intake mods have provided some noticeable seat-of-the-pants boost for a really small investment.
Old 12-17-2011, 01:24 AM
bmax1985's Avatar
bmax1985 bmax1985 is offline
Vehicle: 2007 Dodge Ram Sport 4X4
bmax1985 is on a distinguished road
Anyone have more performance data on this? Would be a great project once I get some free time.
- Brian
Old 12-17-2011, 02:26 AM
TNC TNC is offline
Rep:12
I'm pretty sure no one has done a dyno test on this setup. What would really be neat to see would be some kind of flow bench test where you could compare this modded OEM box and K&N setup to one or more aftermarket CAI setups. I'd suspect the aftermarket setup to be better, but it's possible that one of those may not achieve full potential without headers and a super low restrictive exhaust system. Anyway, all of it is speculation without comprehensive testing. On the other hand, it's just about a given that most stock engines yield some kind of noticeable performance improvement with a decent intake and exhaust modification.
