Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 09-09-2010, 10:31 PM
6speedhemi's Avatar
6speedhemi 6speedhemi is offline
Vehicle: 2006 Ram 2500
Color: Gray
6speedhemi is on a distinguished road
Default Front end jingling over bumps
Hopefully you guys can help me with this. When I go over bumps, big or small, I hear a jingling noise coming from what seems to be the front drivers side wheel area. The best way to describe it is it sounds like loose change jingling in a pocket. All the steering linkage has been upgraded to the new style, the track bar, u joints, ball joints, and sway bar end links feel tight. I can't hear it with the windows rolled up so I know its not loose change actually rattling around in the cab or anything. Any suggestions? Thanks!
2006 Dodge Ram 2500, 5.7L Hemi, 6 speed manual, 4x4, 2" leveling kit w/ 35's, Aero Turbine 3030.
Old 09-09-2010, 10:41 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Have you had anything done with your wheels ? I know someone who had a busted valve repaired and they left the old valve stem in the wheel. So when rolling it sounded like loose change. Just an thought.
Old 09-09-2010, 10:50 PM
6speedhemi's Avatar
Color: Gray
That's a possibility. I'm getting new tires in about a week so if that's the case it'll fix it. I hope it's something simple like that.
Old 09-09-2010, 10:53 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Good luck and be sure to let us know what it turns out to be.
Old 09-10-2010, 08:50 AM
Rep:1909
I notice you didn't mention the shocks. Check your upper shock mount and see if the bushing is damaged/missing. The washer on top rattling around will make a jingling noise.
Old 09-10-2010, 02:41 PM
6speedhemi's Avatar
Color: Gray
Oh ya I forgot to mention that I checked the shocks as well. The bushings are intact and the nut on top is tight along with the bolt on the bottom. Is there a possibility that something internally in the shock is jingling? I've never heard of that happening but I thought I'd ask.
Old 09-10-2010, 02:44 PM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
Had any brake work done before it started?
Brian:
Old 09-10-2010, 11:22 PM
6speedhemi's Avatar
Color: Gray
Well I haven't had the truck long enough to have brake work done. I took the wheels off and looked at the brakes and everything seems nice and tight. Are the anti-rattle clips visible without taking off the caliper? If so those are tight also. This stupid little noise is gonna drive me insane! Thanks for all the suggestions!
Old 09-11-2010, 08:43 AM
Rep:1909
I won't say it's impossible but I haven't seen a problem like that in a long time. The shock woul show signs of fluid leakage.
Old 09-13-2010, 01:00 PM
brandon9654's Avatar
brandon9654 brandon9654 is offline
Vehicle: 2002 Dodge Ram
Rep:28
brandon9654 is on a distinguished road
I had the same thing and the lower shock mount bolt had come loose! if that is the case be very careful you do not break the bolt while trying to tighten it. I broke mine and 350$ later mine was fixed.....new control arm/installation/alignment.
2002 Dodge Ram 1500 Sport // 6" Fabtech Suspension Lift // K&N 57-1529 // SuperChips Flaspaq 3865 // Dynomax Single Exhaust // 325/65R18 Kumho Road Venture AT // Debadged // LED brake light strip //
