Old 10-08-2010, 02:05 PM
WesGPS's Avatar
WesGPS WesGPS is offline
Vehicle: 2005 Dodge Ram HD 4x4 S. Box
Rep:68
WesGPS will become famous soon enough
Question 19.5" wheels?
I'm looking to put 19.5" powder coated steel wheels on my truck. I will probably go with Rickson Wheels - Heather (Sales) is very knowledgeable and easy to talk to.
I just want to know if there are a couple of other manufacturers I should compare to.
I'm not looking for any fancy smancy chrome plated jazz - I'm going to put a big heavy truck camper on the thing so it's all about functionality for me.
If someone can name a couple of other resources I can check out I'll appreciate it.
Thanks, Wes
WesGPS.com
2005 Dodge Quad Cab Heavy Duty 4X4 5.7L Hemi.
Air Lift Remotely Controlled Air Bags.
Hellwig Rear Anti Sway Bar.
Viair Onboard Air System.
Old 10-08-2010, 02:14 PM
Have you looked at BUDD wheels, Wes?
I don't know what they have for the lighter duty trucks (they definitely make big rig wheels) but they might be worth a look.
Of course, there are the Dodge HD 4500 19.5" steel wheels to consider.
You've got Rickson covered in your search.
Accuride is another brand to consider. I know they make dually wheels. Not sure about singles but that is another company to consider.
Alcoa (forged aluminum which is very light and VERY strong) and American Force also come to mind.
Good luck with your search and I hope this info is helpful.
Old 10-08-2010, 03:41 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
they sound fun to find tires for. I have a buddy with 16.5" wheels, and the only tires he can find anymore are used military vehicle tires.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 10-08-2010, 03:56 PM
WesGPS's Avatar
Rep:68
Thanks for the response Michael - I'll do some surfing on the brands you mentioned.
Strang . . . tires won't be a problem. The 19.5" is a standard for which many brands of truck tires are available.
The deal is, I need the stiff sidewall of a steel belted truck tire rather than (normally) polyester side LT (Light Truck) tires. The truck camper I refer to above is real heavy - flexible sidewalls equals fishtailing. I don't need that.
Thanks for the responses.
Best regards, Wes
rickson wheels
