Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Dodge Ram Decals
Old 11-02-2010, 12:06 PM
M0PARMGNUM's Avatar
M0PARMGNUM M0PARMGNUM is offline
Vehicle: 2000 Dodge Ram RCLB - Auto
Color: Green/silver
Rep:27
M0PARMGNUM is on a distinguished road
To keep my tranny happy and extend its life, i drive with O/D off anything below 55MPH or where there are lots of hills or lots of red lights. And while towing...Do not leave O/D on. Or you will regret it. I have over 176,000 miles on my stock trans and it shifts perfect. Also when i start slowing down (if above 55) i wait till i get down to 45 and turn o/d off.. Only mod ive done is the check valve delete. Also when i start up my truck i put it in Neutral to get the fluid pumping threw it and get it warm for atleast 3 mins.. Not sure how the newer trannies are designed but on the 46re the tranny pump does not run in Park..
The O/D Button is there for several reasons. Turn it off in city driving/while towing/in hilly area's/and while having to stop alot/= longer tranny life.
My O/D never see's below 55, i always put it in O/D myself once i get to 55...I hold it there at 55..Turn O/D on..Then i continue to accelerate.. Call be picky, but my tranny is still alive and well.
Old 11-15-2010, 04:26 PM
02haynram's Avatar
02haynram 02haynram is offline
Vehicle: '02 QC Ram
Rep:19
02haynram is on a distinguished road
wow, these are all good question's to solve a matter I didn't realize made a big difference. I'm going to try and run with OD off cause we do mostly city driving with alot of stop&go here and see how it does on the MPG.
Old 11-28-2010, 02:34 PM
mothertrucker
Default O/D issue
I recently towed a buggy across town for a friend with O/D off. Now when on the Highway (55mph+) and O/D on is causing the trans to slip and almost chip gears if this is possible. Could this be a solenoid fix? It rarely slips with O/D off.
I do not need to forget to mention the speedo does not read until i am going any speed above 20 mph. I changed a simple speed sensor and still no fix. I do not want to have to pay to rebuild the trans if something as minor as the solenoid needed to be changed instead. I do not trust any transmission shops, nor do i know anyone that works on them.
Thanks in advance! If this is the wrong place for this question, could someone please pass a link to another forum, ect. Thanks again!!
Old 12-01-2010, 10:20 AM
qsil315 qsil315 is offline
Vehicle: 2003 Dodge Ram 2500
Trim Level: Super Duper
qsil315 is on a distinguished road
Originally Posted by nanney1 View Post
O.K. a couple of questions about the O/D off. At what speeds are we talking about where it would help?
I do a good bit of driving on rural roads where the speed limit is 45 mph. Would this be an application for O/D off? Ocassionally, the limit will drop to 35 and sometimes go up to 55. I don't do any stop and go city driving.
At what point is it better to run with O/D on? 55 mph, 60, 65????
Also, should you be at a complete stop to switch from O/D on to O/D off? I know it can be done on the fly, but is it harmful for the tranny to be driving with O/D off at 55 mph and switch to O/D as I approach highway cruising speeds. Or vice versa... I go from 65 mph down to a 45 mph zone and switch to O/D off.
dude all you have to do is look at your tach to answer your question. drive for a bit with od off and a bit with od on. the lower your rpms stay, the better mileage youre getting if your going the same speed. its pretty simple math bro, dont make it rocket science.
Allow me to introduce myself....
Old 12-02-2010, 04:35 PM
nanney1 nanney1 is offline
Vehicle: 2006 Dodge Ram
Trim Level: SLT Quad
Color: Inferno Red
nanney1 is on a distinguished road
Maybe simple, maybe not. A couple of different things going on here.
From what I've read here, lugging the truck at low rpms with O/D on may cause lower fuel mileage than running higher rpms with O/D off at the same speed. I guess the idea of the engine being in a better power band results in better mileage for lower speeds. Seems counterintuitive, but that's what I'm reading here.
The other point that was made was that running with O/D off at lower speeds is better for the life of the tranny. Different issue than mileage.
