Old 10-09-2010, 03:31 PM
Citabria Citabria is offline
Vehicle: 2010 1500 Bighorn Crew Cab
Trim Level: Bighorn
Citabria is on a distinguished road
Default HID Conversion
I am thinking about converting my 2010 Ram 1500 with headlights to HID on the low beams. Suggestions? Also how do you access the bulbs? The manual appears to be a bit vague. Thanks in advance.
Old 10-09-2010, 03:35 PM
Not sure how you access the bulbs but I suspect getting to them requires you pull the headlight capsule. There are some threads (sorry, don't have the links at my fingertips on the 2010 headlight removal but they are there) in the Custom Lighting section that may help.
As far as the kit themselves, don't go cheap. For some reason these trucks have some touchy electrical systems. Get a good kit and if you want a couple of suggestions, check with 3B Specialties or AAC, one of our supporting vendors here. They are great to deal with!
Old 10-09-2010, 04:03 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I've read the manual on changing the headlight bulbs and you're right, its a lousy how-to. You have to pull the grill then unbolt it from the back side via the panel in the front wheel well. Next pull the assembly. Dumb design if you ask me.
A good kit should have good instructions on how to remove the old and put in the new.
Brian:
Old 10-27-2010, 08:03 PM
guido1000 guido1000 is offline
guido1000 is on a distinguished road
Citabria, just received my HID conversion for Low-beam (H11) and fog (9005/9145) from 3B Specialties, good prices and fast service. No vehicle specific instructions. Will probably attempt this weekend. Will let you know.
Old 10-27-2010, 08:14 PM
ScatPak07's Avatar
Rep:970
if you are going to get the low beam and fogs then 3B Spec would be the place to go.
Old 10-27-2010, 09:01 PM
bigdrams's Avatar
bigdrams bigdrams is offline
Vehicle: 2010 Ram 1500
bigdrams is on a distinguished road
Yes you have to pull the grill off and the headlight too.
Old 11-01-2010, 07:52 PM
Thank heaven for doz post.
http://www.ramforumz.com/showthread.php?t=58736
Without his pictures on how to get to the lights and suggestions about where to install the ballasts, I would still be in the shop.
Low beams were completed in under two hours with 4 coffee breaks (hey it was a Saturday morning) and the fogs took 1 hour and a phone call to TX because one fog did not work. Turns out the connector that goes into the factory harness can go in either way, flipped it and now works great.
Cannot say enough good things about 3B Specialties. Outstanding and fast service, answered the phone on a Saturday and great prices. To top it off, I did not realize I snapped one of the tabs off a low beam causing it to tilt up. Definitely my fault, but Hanh gave me a discount on a replacement pair of bulbs. Not bad to have a spare around.
My only regret was not getting the high beams!
Old 11-01-2010, 10:44 PM
cannotdodgethedart's Avatar
cannotdodgethedart cannotdodgethedart is offline
Vehicle: 1998 Dodge Ram SS/T
Trim Level: Super Sport Truck
cannotdodgethedart is on a distinguished road
DDM kits are also very reliable and cheap as well
