Old 10-09-2010, 06:08 PM
stainlessdreams's Avatar
stainlessdreams stainlessdreams is offline
Vehicle: 2005 heavy duty ram 4x4
Color: silver
Rep:42
stainlessdreams is on a distinguished road
Default whats everyone doing for rust prevention?
i am wondering what everyone is doing for frame rust prevention and under hood rust prevention.
ill let you in on what i do, i try to wash my trucks undercarraige at least once a month at the car was then i use there wax cycle and put a good coat of wax underneath it, then once dry i give the entire underside a coat of wd-40, pb blaster, or similar to keep a lube coating on the underside.
i 4x4 regularly and its a 05 and i dont have any rust under there yet. i am however wondering on the long term effects of spraying wd or pb blaster under my truck, will it eat bushings? because ive noticed im due for an entire bushing replacement which i am going to replace with polyurethane bushings, is it ok for all electrical connections? the only place i dont spray it is my exhaust (cause i did it before and it smoked for a long time)
is there any other methods people use?
!!!GO CANUCKS GO!!!
Old 10-09-2010, 06:33 PM
Rep:2657
I see that you are up in Canada, there is a company up there that does rust prevention
http://www.krown.com/#default
Old 10-09-2010, 07:58 PM
Color: silver
Rep:42
i like the look of that product and very affordable to, i think ill do both my 4x4s
!!!GO CANUCKS GO!!!
Old 10-09-2010, 08:04 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: 2015 RAM Quad Cab Sport
rick980 is on a distinguished road
Ontario Rust Protection.....Oil Spray, Got it done over a year ago, messy but stays good, dripless kind. I should have went for a respray, they do the hitch all over. No rust under there and well I would say it would not have any seized bolts ever, messy when working under there.
Old 10-09-2010, 08:09 PM
Color: silver
Rep:42
so its a coating? i already looked into an undercoating and i didnt like the idea that everything gets coated, it locks in moisture and makes it very hard to work on.
That krown product is more like what im looking for i think.
!!!GO CANUCKS GO!!!
Old 10-09-2010, 08:32 PM
Krown sounds like a interesting product . I wonder why there are no dealers here in the USA ?
Old 10-10-2010, 05:07 PM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
i prevent rust by living in the desert
Old 10-10-2010, 05:39 PM
Rep:2657
I did some reading & found out that a company called RUST CHECK & KROWN may have started as the same company at one time.
KROWN is ONLY in Canada & RUST CHECK is international, but, no dealers come up on their site, right now it just reads Kmart??
http://www.rustcheck.com/theProcess.asp
Old 10-10-2010, 05:47 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Had mine done by Krown last April, one month after I got it. Will be having it sprayed every spring. Very inexpensive for the protection you get. Need it up here as they use alot of salt during the Winter.
Old 10-10-2010, 08:45 PM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
Thats a good one I don't drive the truck much in the winter. I know having a 4x4 in ND and not driving it in the winter. If I do, it's because there is so much snow you can't get around in a front wheel drive car. As soon as the sand and salt trucks come out, the truck goes back in the garage. Then gets a cleaning, just to make sure.
DAFOOT
