EGR codes after a DPF delete? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-26-2010, 03:23 AM
lancinator lancinator is offline
lancinator is on a distinguished road
Default EGR codes after a DPF delete?
I gave up and bought the smarty jr with the ME software to do the DPF delete. so far the mileage increase seems really good. the sound is not much different, just a little louder but nothing like my old 01. My only problem now is i always get an EGR code. I've cleared it and it comes right back. also when i first did the delete i could not figure out why my truck was smoking continuosly. I had to unhook a throttle valve under the hood then that problem went away. I don't know if there is any way to get around the engine light coming on for the EGR unless i spend about another $140 and do the EGR delete too. does anyone know a way around it?
Old 09-27-2010, 09:34 AM
79ta 79ta is offline
79ta is on a distinguished road
I have the smarty jr with the ME software and have not had a code (1500+ miles). I installed it following the instructions, step by step, which had me unplugging the egr before loading the smarty tuner. The code more than likely is from having the egr plugged in and the new program installed. I know the program turns the dpf system off but not sure if the egr is turned completely off. Call the company you purchased the smarty from and ask them for help.
