Old 10-12-2010, 09:39 PM
Earl Branham Earl Branham is offline
Vehicle: 1998 Dodge Ram
Color: Forest Green Pearl
Earl Branham is on a distinguished road
Default Front steering.....
Got in the Ram today, and took off, only to get a big wobble in the front end. Pulled into my friendly auto shop, and found the ball joint on the upper left was about to come apart. In fact, all were bad. Had him fix them, and give the old bus an alignment.....$650 later, all was well. My question, is this a usual thing on these? It is a 1998 with 83K miles. Thanks,
Old 10-12-2010, 09:43 PM
Well , all the ball joints from the factory are not greasable pieces . I believe it's only the uppers . Hopefully the replacements are greaseable pieces . Make sure their greased at every oil change .
Old 10-13-2010, 02:40 AM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Tom summed it up pretty good....ya at the kind of mileage it sounds about right, and if you got some good ones put in then all should be good for a long time, alot longer then the factory ones if there greasable too
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
