Old 10-10-2010, 04:41 PM
JadePriest
Default Enough truck to pull this trailer
I am buying a Puma 31KBHSS which is a pull behind trailer that is 35' hitch to bumper. Total dry weight is 7874 pounds. I am looking at the 2011 Dodge TRX I believe that is the model that has the 3.92 rear axle ratio. I am not going to be doing much pulling probably 3 hours up to the lake then a month later 3 hours home. I was looking at a 3/4 ton but would rather get a 1/2 ton if I can. I just reliezed I put this in the 2010 forum not the 2011... sorry
Old 10-10-2010, 04:50 PM
UnLiMiTeD UnLiMiTeD is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:0
UnLiMiTeD is an unknown quantity at this point
you can get the 3.92's on SLT, sport, laramine or the TRX. Should pull it fine with the proper hitch
Old 10-10-2010, 05:01 PM
Rep:2657
here is the towing capacities of the 2010-11 rams
http://www.dodge.com/bodybuilder/201...mlupseries.pdf
Old 10-10-2010, 08:42 PM
cole3986 cole3986 is offline
Vehicle: 2010 Crew Cab 4x4
Trim Level: SLT Big Horn
Color: silver
cole3986 is on a distinguished road
The towing ratings are almost identical between a ram 1500 & 2500 (3.91 gears vs. 4.10)-that is why I purchased a 1500-just made no sense to me to buy a 2500 if towing is the main issue- and a 1500 with 3.55 gear tows about 1,400 lbs less than with the 3.92 (9,900 lbs v. 8,400 lbs)- Therefore, you are fine with 3.91 or the 3.55 gears. If you really have to tow a heavy load with a gas engine- ford is the better choice- the 2011 F250 with the 6.1 gas engine is rated at 12,500 lbs (yes I know we all love our rams but reality is reality).
Old 10-31-2010, 10:37 PM
DodgieDan DodgieDan is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab
DodgieDan is on a distinguished road
The new Outdoorsman is rated at 10050 lbs towing capacity, and just ordered one to tow my 5th with. 5th is a Chaparal Lite that peeks out at about 9980 lbs with all tanks full and everything you will ever need for a trip. (that includes grey and black full after a dry camping trip) I have been towing it with my 2002 4.7 1/2 ton but am looking forward to the added power of the Hemi.
