Old 10-10-2010, 07:44 PM
NCBowhunter NCBowhunter is offline
Vehicle: 2003 Dodge Ram
Trim Level: Loaded!
Rep:20
NCBowhunter is on a distinguished road
Default Front of truck not level - Left to Right
I have ReadyLift torsion keys coming in the mail soon, I measured from the fender to the top of the wheel on both sides and I was about 3/4" higher on the left side. So when I put the keys on, I want to make sure I raise it 2 inches, I don't want to go too high and mess up my CV angles or something. So do I use the left or ride side as a "starting point" and go up two inches from that point? Maybe someone else who has a stock truck can tell me your height from that point?
Old 10-10-2010, 07:55 PM
jblood05 jblood05 is offline
jblood05 is on a distinguished road
I have a 05 quad cab and mine was 33" from the wheel lip to the bottom of the fender. I installed pro-comp keys and now its 34 3/4" if that helps
Old 10-10-2010, 08:18 PM
Trim Level: Loaded!
Rep:20
I will see what mine is tomorrow thanks. The only problem i see with that measurement is that it includes your tire sidewall which can vary, different tire size, tire wear, inflation, etc.
Old 10-10-2010, 10:03 PM
ScatPak07's Avatar
Rep:970
Maybe go off the lower side to be safe. Really it should come to the rear height. So if you want measure the rear height on both sides. Then take of around 2" (which is average leveling kit heights) off and then that should tell you which side is right.
Old 10-11-2010, 05:57 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
My truck sits about a 1/2" lower on my drivers side.There is no truck out there that is perfectly level from the factory.How can I level my truck on my drivers side?Although it could be my driveway too lol.It isn't level either.
Old 10-11-2010, 09:46 AM
Rep:1882
Ride height measurements aren't taken off the body but rather the suspension. This is why some vehicles may be a bit higher on one side.
Old 10-11-2010, 10:33 AM
Rep:463
Gotcha.How can i fix this or can I?
