Old 10-11-2010, 09:39 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I think it's your tune.
Typically, this is how I've seen a basic tuning session go:
1. easy baseline run just to make sure your aren't running lean and to check a/f.
2. add a couple of degrees of timing and make another run double checking a/f and adding fuel as necessary.
3. you repeat step 2 UNTIL you see a decrease in power then go back to your last setting.
Obviously, you can only add so much timing depending on your octane and whether or not you are running a meth/water setup. If it was a high hp setup then you would also monitor injector duty cycle and fuel pump duty cycle none of which you should be worried about at this point.
These trucks also have knock sensors and the computer would send that data to the dyno. It would be displayed as a dip in the hp/Q curves from timing being pulled.
Old 10-11-2010, 10:06 PM
I push the skinny pedal
Rep:3277
It does look like a good run, a nice flat curve, but I'm surprised he pulled timing instead of advancing it to improve the tune. I'd like to hear the guy's reasoning for pulling the timing, so keep us in the loop.
Kurtis
Old 10-12-2010, 12:58 PM
mark09sport mark09sport is offline
Vehicle: 2014 Ram RC SB
Color: Blue streak pearl
Rep:18
mark09sport is on a distinguished road
Yah, a higher altitude and heat would definitely account for some loss.
Here in Denver, 5,400 ft, it can be almost 20% loss in power.
2014 Ram Express 4x4 Reg cab Short bed 5.7, 8spd, 3.92 gears, Blue streak pearl with all options. 180 T stat, drop in, wrapped intake tube, 24" Mufflex, 2 1/2 lift, Black out ram emblems, Tail light tints.
More MODS to come!
Old 10-12-2010, 02:21 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
oh i remember the parish silverado..that truck was bada$$!!! loved his vids..
Old 10-12-2010, 08:36 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Yeah i talked to him today and it was hitting the knock sensors also i have the log data if you guys want it i cant tel what any of it is cause it in notepad format so just let me know if you want it or not. I think it would be a great idea to get a Dyno Section on the forum what do you guys think?
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
