Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 3.7L (226 cu in) PowerTech V6 Specific Topics
Old 10-11-2010, 06:32 PM
floridacummins777 floridacummins777 is offline
Vehicle: 2010 Dodge ram
Color: Infero Red
floridacummins777 is on a distinguished road
Default v6 rated for more towing capacity then the 5.7?
i read on the dodge site that the dodge ram st has more maxium towing capicity then the 5.7? is this true?
2010 dodge ram 2wd
Old 10-11-2010, 10:03 PM
bighorn10's Avatar
bighorn10 bighorn10 is offline
Vehicle: 2012 Ram 2500
bighorn10 is on a distinguished road
What do you think?
Old 10-12-2010, 12:12 AM
I push the skinny pedal
Rep:3308
I'd have to see the page that says that... cuz it sounds like a bunch of bollocks to be.
Kurtis
Old 10-12-2010, 09:07 AM
Resident Technician
Rep:1909
In terms of total weight when you combine the truck and trailer, I could see where they might say that. Will it pull it like a Hemi? Notta chance!
Old 10-13-2010, 01:52 PM
Color: Infero Red
i know that having more power will tow better but the dodge site i dont think is wrong when it comes down to a reg cab v6 compared to a reg cab v8 it says max for the v6 is 9100 and max for the v8 ranges from 8900 to 9000 here is what i came across and it made me laugh.
http://www.dodge.com/hostc/vsmc/vehi...Code=CUD201013
2010 dodge ram 2wd
Old 02-27-2011, 04:58 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
You misread something or its a typo. ST is a Trim not an engine. You can get a 3500 ST that comes with a standard 6.7L Cummins.
Assuming you meant a 3.7L V6 vs a 5.7L V8....
120.5" 4x2 3.7L 3.55/3.92 = 3750 lb
120.5" 4x2 5.7L 3.55/3.92 = 9050 lb
Even the 5.7L 3.21 is rated at 7050 lb.
Source:http://www.dodge.com/bodybuilder/201...ammlup1500.pdf
Gene
Old 03-25-2012, 03:06 AM
DonDoner's Avatar
DonDoner DonDoner is offline
Vehicle: 2011 Ram 1500
Color: Brilliant Black Crystal Pearlcoat
DonDoner is on a distinguished road
2012 Ram 1500 ST
3.7L V6
reg | 6'4" | auto | 4x2
reg | auto | 4x2 | 6'4"
auto | 4x2
Axle
Ratio
3.923.55
Max Payload
1,506lbs
Max Tow
3,850lbs
Ram'n it where ever I can!
Old 04-03-2013, 01:21 PM
ram1500rem's Avatar
ram1500rem ram1500rem is offline
Vehicle: Laramie 2013 ram 1500
Trim Level: Crew Cab 4X4 6.4 bed
Color: 2 tones Black/silver (PX8)
ram1500rem is on a distinguished road
2012 Ram 1500 ST
3.7L V6
Quad Cab | 6'4" | auto | 4x2
auto | 4x2
Axle
Ratio
3.92
Max Payload
1,918lbs
Max Tow
3,450lbs
Old 04-03-2013, 01:51 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Damn 3,500lb that's pathetic. I guess if you don't tow it's fine but some trailers are 3,500lb.
Sean
